Author Topic: Adjusting the IP to match the Holset  (Read 14755 times)
Reply #45March 28, 2017, 05:18:47 am
Gizmoman
  • 1301
Re: Adjusting the IP to match the Holset
« Reply #45 on: March 28, 2017, 05:18:47 am »
The 1.9 is running netter than it ever has. Still, I bought two of these and will mess around with some additional grinding.
http://www.ebay.com/itm/321182846275?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'n not entirely positive they will fit my 1.6 pump but they weren't too expensive.
Reply #46March 28, 2017, 10:35:05 am
« Reply #46 on: March 28, 2017, 10:35:05 am »
Those should fit.
Reply #47March 28, 2017, 12:48:05 pm
« Reply #47 on: March 28, 2017, 12:48:05 pm »
Aren't you a machinist? You could just make a cylinder and then drill and tap the top of it for a bolt rather than what Bosch did with the stud. You could even make it from aluminum until you find the profile you like then make a steel one.
Reply #48March 28, 2017, 03:25:49 pm
Gizmoman
  • 1301
« Reply #48 on: March 28, 2017, 03:25:49 pm »
I thought of that, figured I'd start with a "known" value. Who knows, it might be just right although it looks to steep at the beginning.
Reply #49March 28, 2017, 04:33:50 pm
« Reply #49 on: March 28, 2017, 04:33:50 pm »
I believe the pin should only ride on the single long taper, not on the steeper angle at the bottom.
Reply #50March 28, 2017, 06:28:46 pm
Gizmoman
  • 1301
« Reply #50 on: March 28, 2017, 06:28:46 pm »
Yes, I figured the same, and it does appear there is a light and aggressive angles based on position.
I also ordered and received a new spring with a higher comp rate. It's running quite well now but I can just mark the settings and return to them if needed.
I'll wait for the pins to arrive and try both one of these weekends.
Reply #51March 30, 2017, 08:22:06 am
« Reply #51 on: March 30, 2017, 08:22:06 am »
Where did you get the spring from? I could use one...
Reply #52March 30, 2017, 05:23:41 pm
Gizmoman
  • 1301
« Reply #52 on: March 30, 2017, 05:23:41 pm »
Here you go
https://www.mcmaster.com/#9657k324/=16zhq8x
You get three and I believe it was around nine bucks for the package. Might be too stiff but they are easy to change. I am hoping that, combined with the new pin(s) I am getting from the UK, it will be more of a gradual increase in both fuel and boost ending in decent HP/torque and EGT's below 1200F.
The pins won't arrive for a bit yet and I'm waiting till they do.
