Author Topic: LDA Boostpin Results on 1.9TD AAZ  (Read 2431 times)
February 10, 2017, 09:06:34 am
DkmenchaR
  • 23
« on: February 10, 2017, 09:06:34 am »
I've been looking for an 1.6TD Boostpin to install on my VW Vento 1.9TD, but I don't know if it will make any diference on fuel effiency and boost....
The car is full stock, don't know if my pump it's an 9/10/11mm, it's making around 90hp (my mechanic had some adjust done without rasing PSI, the turbo is a Garrett T15 and don't have a boost gauge either..)
So the deal is: Just installing the Boostpin on compesantor governor, should give some "safe" boost increase ? I would like to surpass the 100hp with this setup (engine have 300k+ miles but still in very good shape and healthy) but for that I think I need to take the kat out, and raising turbo PSI to +/- 14,5  (+/- 1bar, I don't have IC tho...)
I have plans for this old man (IC, Giles Pump, KKK24, 228mm Clutch, larger exhaust pipe....), but for now I want to rebuild this setup @ fullstock until I've damaged something :)
Any tip or help is welcome and feel free to argue the best configs to tune my AAZ  8)
Best Regards
Reply #1February 10, 2017, 11:33:05 am
RunninWild
  • 609
Re: LDA Boostpin Results on 1.9TD AAZ
« Reply #1 on: February 10, 2017, 11:33:05 am »
It will make a difference but you really need to get an egt gauge installed before you start playing with fueling. There is a fine line between more fun and melting pistons.
