Author Topic: Parting out 1.6TD longblock. Everything available but the head.  (Read 4800 times)
February 03, 2017, 09:49:19 am
Jettagli16v
  • 344
« on: February 03, 2017, 09:49:19 am »
Hello, all!
I had a 1.6 MF TD, and I overheated it and cracked the head.
I have had the engine sitting on a stand too long, and before I throw it away, thought I would check here to see if anyone needs anything.
The engine was recently refreshed (new rings, bearings, rebuilt rods, etc..), but of course overheated, so what can you do...
I have it basically broken down. Have all the brackets (except for Alt tensioner: I already sold that), AC compressor, Alt, starter, etc, as well as rods, pistons, crank, block, camshaft, solid lifters, hi flow oil pump, etc...
It has ARP studs, but one won't come out (yet), and I stripped the hex a bit, so if anyone needs a few spare ARP studs, I got you.
I will happily entertain trades for any upgrades to work on an AAZ, as my new Caddy came with an AAZ already installed..
Since I don't log in here too often, the best way to reach me is to email: [email protected] (though I'll try to keep tabs on the thread).
Photos provided on request.
Located in Orlando, Fl.
Thanks!
-Brad
Reply #1February 05, 2017, 02:32:42 pm
Big guns
  • 1
Re: Parting out 1.6TD longblock. Everything available but the head.
« Reply #1 on: February 05, 2017, 02:32:42 pm »
Do you still have the connecting rods can you give me a price on those and I need the two dowel pins on top of the block to lineup the head
Reply #2February 07, 2017, 07:42:27 am
Spokerider
  • 195
« Reply #2 on: February 07, 2017, 07:42:27 am »
I sent you an email for the arp studs, oil pump and more.........
Reply #3February 07, 2017, 11:19:19 am
Jettagli16v
  • 344
« Reply #3 on: February 07, 2017, 11:19:19 am »
All emails replied to.
On another note, the TD Injection Pump, lines & injectors are all gone. They were put on my 1.6NA car, and were sold with the car.
Big Guns:
I got an email about the con rods (not sure if it was you or not), I would say $100 shipped to the US? They were recently checked, and found to be in spec as of 3000 miles before the engine overheated.
Also, if anyone is located in Central Florida, prices will be lower if you come pick it up.
I just need to get rid of this stuff and move on.
Thanks!
-Brad
Reply #4February 09, 2017, 11:27:11 am
Jettagli16v
  • 344
Reply #5February 24, 2017, 09:50:06 am
Tmarkle
  • 153
« Reply #5 on: February 24, 2017, 09:50:06 am »
Still have the turbo and associated parts? Manifolds, turbo, oil feed line, oil pan, etc? Looking to add a turbo to my 1.6NA.
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #6March 07, 2017, 10:27:42 am
Jettagli16v
  • 344
« Reply #6 on: March 07, 2017, 10:27:42 am »
Sorry about the delay, haven't been over here in a few weeks.
Turbo is gone.
I still have the exhaust manifold: Tapped for Aircraft Spruce EGT pre-turbo. Still not 100% that I want to let this go, it might be needed on my AAZ.
Oil lines: have both. Both were purchased new from VW dealership.
Oil pan is currently up on ebay. It's an OEM one I bought at the dealership because the one on the car was stripped.
Feel free to send an email to follow up.
Thanks!
