Author Topic: Adjustable pump sprocket......how to set the timing?  (Read 2800 times)
January 27, 2017, 01:12:48 pm
Spokerider
  • 195
« on: January 27, 2017, 01:12:48 pm »
My 1995 Golf has an adjustable injection pump sprocket......the one with the little square notch / 6mm round hole in pump housing, and the three bolts that hold the sprocket to the pump.
I want to set the timing. I have read that you just set the crank to TDC, the cam lobes "up", the timing marks on the flywheel to TDC, and then loosen / rotate the pump sprocket until the notch aligns up with the round hole, no dial gauge measurement or adjustment needed......done.
Well, exactly what number will the time be at? .085? I want it to be set at 1.0mm, as this engine has 200k on it.
 Can I still use a dial gauge and set the timing to 1.0mm like I have done with other aaz's that have the round inj pump pulley holes to line up?
This car has sat for 2 years, will only idle with the cold start fully pulled out, idles very rough, much smoke, but when the engine revs are increased to say 2000, then it smooths out.
Plan is to check / set timing, new fuel filter, run a can of diesel purge and see how it goes from there.
Reply #1January 27, 2017, 02:38:24 pm
RunninWild
  • 609
Re: Adjustable pump sprocket......how to set the timing?
« Reply #1 on: January 27, 2017, 02:38:24 pm »
I think it's just trial and error with that pump. Put the ip lock in, loosen the 3 bolts on the sprocket, rotate the engine counter-clockwise a tiny bit and tighten the bolts,  Remove the lock, rotate back to tdc and then check timing with the dial gauge. Repeat this until you're at 1.0mm
Reply #2January 27, 2017, 05:40:06 pm
« Reply #2 on: January 27, 2017, 05:40:06 pm »
you can still use the gauge. It is actually easier. set up the gauge normally then loosen the gear and set the timing as you want.
Reply #3January 27, 2017, 07:00:08 pm
Spokerider
  • 195
« Reply #3 on: January 27, 2017, 07:00:08 pm »
Ok, thanks guys.
 I did set the cam timing as it was off a few degrees, then set the pump timing with the dial gauge to .98mm. I THEN remembered that I didn't have the cold start cable pushed in..........grrrrr. will have to do it again later......ran outta daylight today.
Does anyone know the torque specs for the 3 injection pump sprocket bolts? Can't find it anywhere.
 Thank you.
Reply #4January 28, 2017, 07:52:47 am
« Reply #4 on: January 28, 2017, 07:52:47 am »
Not sure but I think they are 18ft/lbs
Reply #5January 28, 2017, 08:37:24 pm
Spokerider
  • 195
« Reply #5 on: January 28, 2017, 08:37:24 pm »
Hummm......18 ft lbs *seems* light  ???
