Author Topic: Do VW diesels ever jump timing?  (Read 4887 times)
April 12, 2006, 08:12:53 am
Busdriver
  • 22
« on: April 12, 2006, 08:12:53 am »
I have a AZZ that has decent compression, and cranks, but won't start (it was running).  The glow plugs are working. Could the timing slip one belt notch & so that the engine won't run,  without being so far off that valves are slamming into the pistons?  :?:
John Koloski
98 Jetta TDI
90 Vanagon 1.9TD AAZ
occasional biodiesel brewer
Reply #1April 12, 2006, 08:22:19 am
BlackTieTD
  • 1512
« Reply #1 on: April 12, 2006, 08:22:19 am »
pretty sure even 1 tooth will slap valves... does it turn over by hand if you put a socket on the crank?
Reply #2April 12, 2006, 09:18:38 am
Busdriver
  • 22
« Reply #2 on: April 12, 2006, 09:18:38 am »
Yes, I can turn it over by hand.
John Koloski
98 Jetta TDI
Reply #3April 12, 2006, 09:24:44 am
BlackTieTD
  • 1512
« Reply #3 on: April 12, 2006, 09:24:44 am »
what has changed since it started last?
is it getting fuel?
do you have 12v to the stop solenoid?
Reply #4April 12, 2006, 11:30:35 am
Kevin L
  • 20
« Reply #4 on: April 12, 2006, 11:30:35 am »
I have had a timing belt drive sprocket/pulley come loose and break it's key while driving home. It continued to loose power (smoking)  untill it  quit leaving me on the side of the road. Talking to a couple of shops  they said all the valves were bent and I should go look for another motor.
Being stuborn I put another (used) pulley and bolt  in with a new belt, retiming it as well.  I was lucky it ran for another 120K
This was a 1.6NA jetta
 you may be lucky
90 Jetta Turbo Diesel 425K and counting
