Author Topic: Starter not engaging every start, 1.6  (Read 6024 times)
Reply #15January 02, 2017, 06:06:14 pm
sgnimj96
  • 185
Re: Starter not engaging every start, 1.6
« Reply #15 on: January 02, 2017, 06:06:14 pm »
starters motors are actually pretty tough,  the solenoid is what usually goes bad.    They want you to buy the whole thing so solenoids are kind of overpriced and hard to find,  but you can get em online if you search.   Plenty of how-to's just on youtube for testing and fixing starters.
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #16January 04, 2017, 06:36:47 am
Heron
  • 60
« Reply #16 on: January 04, 2017, 06:36:47 am »
Yes, looked into the solenoid. So far the old starter is working great but may only for a short period.
I thought you would have to utilize special tools to braze the wires correctly and all...I'll look into it further if this starter decides to quit again. Thank you!
Reply #17January 06, 2017, 08:08:47 am
« Reply #17 on: January 06, 2017, 08:08:47 am »
The mk4 TDI automatic starter is a readily available bolt-in upgrade starter for the Mk1.
Reply #18January 07, 2017, 05:31:56 pm
Heron
  • 60
« Reply #18 on: January 07, 2017, 05:31:56 pm »
Thank you for that information. So far the old starter is working fine but it may be short lived.
Reply #19January 28, 2017, 04:41:27 pm
RustyCaddy
  • 395
« Reply #19 on: January 28, 2017, 04:41:27 pm »
...The third issue can be addressed by...adding a 'hot start relay' which will actually help your ignition switch last longer by reducing the load through it.
That is a really good idea!
