so i do believe theyre 2 piece proportioning valves, the bottom has 2 slots for an open-end. so take them out; put bottom end in a vice, the top should take a wrench, see if its loose; if so thats your problem; you can now either tighten up ,,-or take apart and clean up, a new o-ring in there, and tighten; i dont think you can find a torque for this, although some where there may be one, tighten so it wont leak, i tighten some more(a little), i has to not leak for some while,,.
