Author Topic: AAZ k14 on 1.6 td CY  (Read 5998 times)
October 12, 2016, 04:51:09 am
kljaja
  • 38
« on: October 12, 2016, 04:51:09 am »
I've searched the net but haven't found a clear answer..
I have 1.6 td CY code with kkk k14 turbo thats worn out (has some shaft play and leaks oil as crazy)
I want to replace it with fresher unit and i wanna know if i can search units from an AAZ engines.
Is k14 from AAZ straight bolt on to my engine or it needs fabrication to match exhaust, intake, downpipe and oil feed?
Edit:
Turbo i have available is
K14 7009
028145703e1
Mine is:
K14 6082
Cant read oem nr. As turbo is still in car
« Last Edit: October 12, 2016, 07:36:16 am by kljaja »
Going fast never killed anyone, suddenly becoming stationary, thats what gets ya
Reply #1October 12, 2016, 08:39:32 am
Re: AAZ k14 on 1.6 td CY
« Reply #1 on: October 12, 2016, 08:39:32 am »
yes it should just bolt on, the only thing that would be different is the oil drain, but i think both k14's have the same drain
Reply #2October 19, 2016, 11:20:36 am
kljaja
  • 38
« Reply #2 on: October 19, 2016, 11:20:36 am »
My k14 is aa watercooled + oil cooled unit, ive came across k14 of an aaz and it was oil cooled only, is that still a direct fit? should i just shut the water hoses untill i rebuild my existing k14? Ive got an offer for a t2 thats watercooled and oil cooled but its quite expensive. Market here in Croatia is pretty bad, people that sell used parts for these TDs usually dont even know what model turbo theyre selling...and those who know usually price them too high...
Reply #3October 28, 2016, 08:53:51 am
kljaja
  • 38
« Reply #3 on: October 28, 2016, 08:53:51 am »
hello, i've swapped my old k14 with another one, a lot less shaft play and seems to spin more freely by hand. Thing is that exhaust side housing is missing one of the bolts fot downpipe mounting. I've put everything on hoping it wont leak exhaust gasses but it seems to leak smoke a fair bit...
Can i just screw the remaining hole with M8 1,5" bolt?
« Last Edit: October 28, 2016, 11:53:51 am by kljaja »
Reply #4October 28, 2016, 09:00:02 am
air-cooled or diesel
« Reply #4 on: October 28, 2016, 09:00:02 am »
sounds like you want a special 'grade' hardware, alloy for high heat/turbo usage. either get in contact with VW(online or otherwise) or a turbo shop, and get size.
Reply #5October 28, 2016, 11:15:07 am
« Reply #5 on: October 28, 2016, 11:15:07 am »
hello, i've swapped my old k14 with another one, a lot less shaft play and seems to spin more freely by hand. Thing is that exhaust side housing is missing one of the bolts fot downpipe mounting. I've put everything on hoping it wont leak but it seems to leak fair bit...
Yes, you can.  I would recommend sealing the threads with Permatex Ultra Copper.
Reply #6October 28, 2016, 11:43:16 am
kljaja
  • 38
« Reply #6 on: October 28, 2016, 11:43:16 am »
i have this exact case...
So there shouldnt be a problem if i use ordinary bolt instead of threaded bar with nut like other 3 ?
« Last Edit: October 28, 2016, 11:53:19 am by kljaja »
Reply #7October 28, 2016, 03:50:05 pm
« Reply #7 on: October 28, 2016, 03:50:05 pm »
you wanted a stud, maybe with loctite, pr
« Last Edit: January 24, 2017, 03:38:06 am by air-cooled or diesel »
Reply #8October 28, 2016, 04:40:08 pm
« Reply #8 on: October 28, 2016, 04:40:08 pm »
One of the studs for the downpipe?  I misunderstood.  Get another stud and copper nut.  They're dirt cheap.
« Last Edit: October 28, 2016, 06:48:02 pm by libbydiesel »
Reply #9October 28, 2016, 05:47:05 pm
kljaja
  • 38
« Reply #9 on: October 28, 2016, 05:47:05 pm »
Yeah, it's stud that i need, sorry but my mechanical terms in english suck, they suck in my mother language as well  ;D
I'll try to find the one i need tommorow after i attach that horrible C clamp on exhaust which is major PITA
I'm hoping for healthy 12-15 psi with conservative amount of coal before i put IC and 2,5" on it
Reply #10October 28, 2016, 08:30:46 pm
« Reply #10 on: October 28, 2016, 08:30:46 pm »
that right there seems to be a hard nut to trace down, although i suppose a std exh copper nut will do, im sure its a little more special, and ive tried autohaus, they have flange gasket, but not nut, next try to call partsplace.
