S-PAutomotive.com
Author Topic: Passat B3 tach problem  (Read 3754 times)
September 02, 2016, 02:29:38 pm
Pawy
  • 2
« on: September 02, 2016, 02:29:38 pm »
Hello!
First of all here is a video of the problem:
http://youtube.com/watch?v=G2I3U_vulKc
And a little back story, now week ago I bought a 1993 Passat B3 1.9TD (AAZ), it didn't had a tach, so I found one with tach, but only thing is that it's from B4 US or UK model. Basiclly it's jumping all over the place. At current time I have checked my wires by the alternator and they looked good, so I'm thinking is there a problem in car or it's cluster.
Any ideas or advice in this situation would be much appreciated.
« Last Edit: September 02, 2016, 06:44:07 pm by vanbcguy »
No smoke, no party!
Reply #1September 02, 2016, 06:47:30 pm
  • Administrator
  • 2831
Re: Passat B3 tach problem
« Reply #1 on: September 02, 2016, 06:47:30 pm »
Is the cluster for an AAZ or a TDI? The tach signal from the alternator is a much higher frequency than most tachometers expect. If it's a TDI tach rather than an AAZ tach it's probably expecting a signal from the crank speed sensor which sends 4 pulses per revolution. The alternator sends out probably 10 times that, which would lead to exactly the behaviour  you are seeing.
S-PAutomotive.com
