Author Topic: Camshaft interchangeable between heads?  (Read 1956 times)
August 25, 2016, 01:15:47 pm
oblique
  • 317
    Diesel while you can.
« on: August 25, 2016, 01:15:47 pm »
1.6TD MF.
Heres the thing. I blow a lot of smoke on WOT and with a little oil in the coolant reservoir Im sure Ive got a cylinder head issue of some kind. I found a clean, cheap '85 TD head on local classifieds and drove out 2 hours to get it. When I got there I realized why it was so cheap: the cam and securing blocks were missing. Being all the way out there I took it. The question is: when i swap the heads can I port my existing cam and blocks to the new replacement head? They are both hydro heads.
At the same time I might as well do my timing belt. Is there anything else I should change while I do all this? What can I/should I check before ordering parts?
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #1August 25, 2016, 03:19:17 pm
Re: Camshaft interchangeable between heads?
« Reply #1 on: August 25, 2016, 03:19:17 pm »
The cam caps are specific to the head casting they were paired with (much like main bearing caps). You will need a machine shop to line bore the cam journals assuming they can make those caps work. Or you can just swap heads...
