Fixmyvw.com
Author Topic: Axial play on pump shaft?  (Read 2334 times)
August 13, 2016, 10:45:39 pm
motohead1
  • 10
« on: August 13, 2016, 10:45:39 pm »
Is there a axial play measurement for the bosch pump?  I picked up a LR pump and see some play in the mainshaft axially only when I turn the pump by hand.  but I caint find the stock spec anywhere.  Here is a video.
https://goo.gl/photos/kJt1XRftTorbTswV6
« Last Edit: August 15, 2016, 10:03:07 pm by motohead1 »
Reply #1October 26, 2016, 12:16:37 am
  • 3416
Re: Axial play on pump shaft?
« Reply #1 on: October 26, 2016, 12:16:37 am »
There is normally some play.  I don't know what the spec is.  The video looks normal.
Reply #2October 26, 2016, 08:48:33 pm
motohead1
  • 10
« Reply #2 on: October 26, 2016, 08:48:33 pm »
Thanks.  Since I couldent find a solid answer a few months ago I decided to ETdi my swap since I had a good complete running car.  But knowing this play is normal I will probably do a comparison between E and Mtdi.  Id like to be able to switch between the 2 if needed.
S-PAutomotive.com
