Author Topic: MTDI VNT Control  (Read 8053 times)
July 31, 2016, 12:00:36 pm
payday
  • 1
MTDI VNT Control
« on: July 31, 2016, 12:00:36 pm »
Good afternoon,
I'm Patrick from the Netherlands, my excuse if my English isn't verry good...
I'm building a, AFN M-TDI in my Caddy MK1.
I have a small problem running my VNT 15 turbo on this engine; i'm searching for a VNT controller.
Is it possible to make the VNT 'boost controlled' ?
I've seen a boost controlled turbo on a 2.8 AGK Engine!?
Is there anybody who can give me a good idea how to make my VNT work?
I hope you people understand my problem and can help me fix it :)
Reply #1August 13, 2016, 01:00:41 am
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
Re: MTDI VNT Control
« Reply #1 on: August 13, 2016, 01:00:41 am »
There's two ways to do this: (1) electronic control, usually using boost pressure to move the vanes, and (2) a mechanical linkage to impart the boost pressure to move the vanes.   Here's my system using method (2).
This is a fully mechanical VNT vane control system that is entirely based on libbydiesel's design and fabrication from a few years ago (actually, he provided me my stock vacuum actuator modified to operate on boost pressure by flipping the internals.  He also selected a new spring with characteristics so that it linearly opens the vanes from closed to fully open at approximately 20 psi).  I built the rest.   Almost all parts are from McMaster-Carr.
Heim joints and threaded rod ends make it completely adjustable.   I built it stout so it doesn't bind or bend.  I had to change my AWIC location to a slightly more distant location, but still has no lag.
A short video and four photos of the system are on photobucket:
http://s1264.photobucket.com/user/Rock3tman/media/MVI_7211.mp4.html?o=1
http://i1264.photobucket.com/albums/jj492/Rock3tman/IMG_7209.jpg
http://i1264.photobucket.com/albums/jj492/Rock3tman/IMG_7208.jpg
http://i1264.photobucket.com/albums/jj492/Rock3tman/IMG_7207.jpg
http://i1264.photobucket.com/albums/jj492/Rock3tman/IMG_1444-1.jpg
regards, Rock3tman
