Author Topic: Atm compsenator as LDA  (Read 2384 times)
April 10, 2006, 05:53:40 pm
jwspin
  • 138
« on: April 10, 2006, 05:53:40 pm »
i put an atm compensator on my eco diesel to try and see if it works as an LDA. the one prob i ran into is that the two bolts are different sizes so that i cant just swap the vent bolt for the banjo bolt. i know a few people have done this but i couldnt find the threads. can anyone chime in on this topic.
-jared
Reply #1April 11, 2006, 10:47:12 am
jwspin
  • 138
« Reply #1 on: April 11, 2006, 10:47:12 am »
so i got ahold of some banjo bolts and fitting that i think will work but doesent the lower hole need to have a vent on it? should i just leave the stock banjo down there with a rubber cap to keep crud out?
-jared
Reply #2April 12, 2006, 11:34:37 am
jwspin
  • 138
« Reply #2 on: April 12, 2006, 11:34:37 am »
it seems to work. the car is a lot faster. i adjusted the 6 point screw on the top clockwise about 3/4 of a turn and it seems to move along nicely. what other adjustments should be done to it?
-jared
Reply #3April 14, 2006, 08:21:12 pm
moosiah
  • 106
vacume lda
« Reply #3 on: April 14, 2006, 08:21:12 pm »
Hi I've seen the inards of both...... their the same...... the alt comp has a lighter spring than the turbo LDA........    :o
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #4April 16, 2006, 09:19:00 am
hillfolk'r
  • 1532
« Reply #4 on: April 16, 2006, 09:19:00 am »
yea my a2 91 has an altitude pump,,,iwas figuring someday toswap a stockturbo setup on it,,,at least iknow it can be done,,,,igot an extra turbopump,for parts,springs etc,,,,i took out lda once,,,,,it has a tapered pin,,so thats a good thing,,,,,,,,,,,,
Throttle cables ftw
