Author Topic: FS: Stock 1.6TD pistons $50CAD; Set of 4 injectors $40.  (Read 4549 times)
June 30, 2016, 10:50:30 pm
BananaDiesel
« on: June 30, 2016, 10:50:30 pm »
Stock 1.6TD pistons. Very likely replacements as the bores we significantly worn but the pistons are in good shape. All we measured within .0003 to .0008 under nominal. No noticeable wear on the skirts. Comes with writs pins and clips.
Complete set of 4 injectors pulled from working car. $40. Second set of 3 good injectors and 1 with damaged threads for a core charge set $20.
« Last Edit: July 16, 2016, 05:08:09 pm by BananaDiesel »
Reply #1July 01, 2016, 12:02:42 pm
Re: FS: Stock 1.6TD pistons
« Reply #1 on: July 01, 2016, 12:02:42 pm »
Got a price?   I have the potential need coming up for new pistons in the standard 1.6 N/A.   Might look at these if swapable.  Anyone know off the top of their head or do I just need to go do the homework?
Reply #2July 01, 2016, 10:19:16 pm
« Reply #2 on: July 01, 2016, 10:19:16 pm »
You can use the TD pistons in a non-turbo 1.6 engine without any issue/modification.  You cannot use the non-turbo pistons in a turbo engine, though.
Reply #3July 01, 2016, 10:46:51 pm
« Reply #3 on: July 01, 2016, 10:46:51 pm »
Thanks Libby,  Kinda what I thought, Will be tearing head off the Rabbit looking for things that go clank tomorrow.   I wasn't sure of stroke and bore between the two engines.  Saved me having to look it up.
Spent time looking at the new Electric Golf and thinking retirement gift to self.
Reply #4July 03, 2016, 06:23:27 pm
BananaDiesel
Re: FS: Stock 1.6TD pistons $100
« Reply #4 on: July 03, 2016, 06:23:27 pm »
Updated with price.
Reply #5July 03, 2016, 08:48:57 pm
« Reply #5 on: July 03, 2016, 08:48:57 pm »
I am hopeful that the damage to the pistons I saw will not adversely affect the performance of the engine.  I am just going to try running it with a new, thinner HG and I will test some injectors too.  Thanks for the price update.
Reply #6July 16, 2016, 05:08:24 pm
BananaDiesel
Re: FS: Stock 1.6TD pistons $50CAD; Set of 4 injectors $40.
« Reply #6 on: July 16, 2016, 05:08:24 pm »
bump with new price.
