Author Topic: 1.6 Non Turbo to Turbo swap  (Read 4624 times)
June 29, 2016, 01:59:44 am
KyMoonshine
  • 10
« on: June 29, 2016, 01:59:44 am »
Hello, I looked around and could not really find an answer so I thought I would ask, I have been collecting extra parts here and there for my 85 Golf 1.6D non turbo car, I was wondering if the motor and trans from a 92 Eco 1.6 Turbo Jetta would swap into my car? both are five speed cars, if so is there a lot of modification to be done? I know anything can be made to fit anything, I was just wondering if it is a direct drop in situation? Thank you for any info or advice, this forum has been most helpful so far
Reply #1June 29, 2016, 06:46:40 am
srgtlord
  • 797
Re: 1.6 Non Turbo to Turbo swap
« Reply #1 on: June 29, 2016, 06:46:40 am »
Motor and trans will drop right in. Biggest issue you will have is bolting up the exhaust. The turbo exhaust down-pipe is a bit different
Reply #2June 29, 2016, 12:23:37 pm
KyMoonshine
  • 10
« Reply #2 on: June 29, 2016, 12:23:37 pm »
Thank you, I figured I would have to do some exhaust work, is there much difference in driveability/power between the two? and is the 92 geared the same? my Golf does not like freeway speeds lol
Reply #3June 30, 2016, 08:16:23 pm
« Reply #3 on: June 30, 2016, 08:16:23 pm »
The Eco cars usually came with a transmission that isn't set up well for interstate cruising at the 70+ mph speed limits we have today. They were definitely dialed in for 55 mph max. Great around town, not do good on the freeway.
