AAZ Vanagon losing oil
Pages:
4
5
6
Topic: AAZ Vanagon losing oil (Read 25924 times)
Reply #60
May 22, 2017, 06:57:40 am
Re: AAZ Vanagon losing oil
Reply #60 on:
May 22, 2017, 06:57:40 am »
also, i would try to find the fuel line clamps to help prevent them from vibrating and breaking.
I think the electronics on the pump controls the timing advance and timing, kind of like the solenoid on some injection pump timing covers. but i am not sure.
Reply #61
May 22, 2017, 08:48:45 am
RockOcean
Reply #61 on:
May 22, 2017, 08:48:45 am »
I don't have the belt for that set up. I would also have to put on the power steering pump, and a/c compressor to get that to work.
Reply #62
May 22, 2017, 05:04:42 pm
Gizmoman
Reply #62 on:
May 22, 2017, 05:04:42 pm »
Sounds like your real close!
Congrats on getting it in already. I find that setbacks can be good just to keep things going at a logical pace
Reply #63
May 22, 2017, 05:15:48 pm
RockOcean
Reply #63 on:
May 22, 2017, 05:15:48 pm »
I ordered the factory no a/c, no power steering water pump pulley from VW today. Will be here tomorrow along with my old turbo with the correct oil feed adapter on it. Here is a picture of the insane cylinder wall wear on number 4. I don't know how it still ran so well and started up fine with that much wear? Any thoughts on what made it wear like this?
#4CylinderWear
by
RockOcean.com
, on Flickr
Reply #64
May 22, 2017, 06:19:48 pm
Reply #64 on:
May 22, 2017, 06:19:48 pm »
headgasket or injector? maybe a bad oil squirter in that cylinder?
Reply #65
May 22, 2017, 06:45:32 pm
Moderator
4552
Reply #65 on:
May 22, 2017, 06:45:32 pm »
What condition were the rings when you removed them? Almost looks like metal on the top of the cylinder wall. Heat issue?
Reply #66
May 23, 2017, 04:13:44 am
Reply #66 on:
May 23, 2017, 04:13:44 am »
I'm guessing fuel wash or ingested debris.
Reply #67
May 23, 2017, 06:11:20 am
Reply #67 on:
May 23, 2017, 06:11:20 am »
reading over the entire thread it sounds like a lot of dirt did get in the engine, and if you look the other bores are very worn out for a relatively fresh engine so that would make sense.
Reply #68
May 23, 2017, 02:33:14 pm
RockOcean
Reply #68 on:
May 23, 2017, 02:33:14 pm »
Woooohoooo started right up! Time for a 100 mile test run. Thanks everyone for all your help :~ )
Reply #69
May 23, 2017, 04:49:07 pm
Reply #69 on:
May 23, 2017, 04:49:07 pm »
Nice! I'd ditch the K&N and get a filter that doesn't pass the fine dust.
Reply #70
May 23, 2017, 07:20:08 pm
Gizmoman
Reply #70 on:
May 23, 2017, 07:20:08 pm »
Quote from: libbydiesel on May 23, 2017, 04:49:07 pm
That thars melted aluminium - seen it (but a lot worse).
Reply #71
May 24, 2017, 04:44:42 am
Reply #71 on:
May 24, 2017, 04:44:42 am »
K&N=snakeoil
Reply #72
May 24, 2017, 01:06:16 pm
Gizmoman
Reply #72 on:
May 24, 2017, 01:06:16 pm »
Reply #73
May 24, 2017, 01:13:29 pm
RockOcean
Reply #73 on:
May 24, 2017, 01:13:29 pm »
So what cone filter company do you recommend?
Sent from my SM-G925V using Tapatalk
Reply #74
May 24, 2017, 01:30:41 pm
Gizmoman
Reply #74 on:
May 24, 2017, 01:30:41 pm »
Not sure about cone filters specifically but Donaldson makes some good filters that are extremely suited to keep fine dust out of your new engine. There are probably quite a few others that would do the job as well.
https://www.mrostop.com/g070020-donaldson-air-cleaner-fpg-radialseal.html?gclid=CjwKEAjw3pTJBRChgZ3e7s_YhAkSJAASG9Vr7q2z1AUnBYn6_UBrkfIy7FOergLKMMocNYzl5g1SxBoCn_Pw_wcB
You may find something at your local autoparts store that could be swapped into the same housing. Take you filter in and see whats available or possibly check online.
Pages:
4
5
6
