Fixmyvw.com
Author Topic: 1995 AAZ Passat Wagon  (Read 2056 times)
May 05, 2016, 03:14:31 pm
Big Daddy Roth
  • 298
« on: May 05, 2016, 03:14:31 pm »
It's currently registered as a BC vehicle. Offered for sale in "as is, where is" condition. Located in Orillia ON.
This car needs a headgasket replacement. I suspect I overboosted it. White smoke out the back and making pressure in cooling system.
I built this car in BC and brought it with me when I relocated here back in Ontario.
1.9 TD (not TDI)
10000Kms on completely rebuilt engine (oil pan to valve cover)
Rebuilt Giles high performance injector pump
New Holset HE200WG turbo (Cummins 4BT)
Manual boost controler
Giles performance ground camshaft
Rebuilt Injectors
Custom SS 2.5" straight pipe exhaust
G60 intercooler
Digital boost and EGT gauges
Larger VR6 radiator
New starter, battery and 120A Alt
Freshly rebuilt CTN O2A transmission
Newer Stage 2 SBC clutch and flywheel
VR6 front sub-frame and rear beam (5x100 wheels and bigger brakes)
Newer brakes front and back
Newer upgraded rear calipers
Newer ball joints
Raceland coilovers (stock suspension available)
Whiteline control arm bushings
Clean black leather interior
Everything electrical works as it should.
OEM alarm / keyless entry
European E-code glass headlights
European smoked taillights
Blaupunkt bluetooth stereo
Small receiver hitch
Heater core recently replaced so A/C needs to be recharged (works well)
Clear coat is peeling on roof and hood. A few rust spots (Drivers 'A' pillar, RR wheel arch) BC rust, not Ontario cancer.
$2500 obo "AS IS" condition. Serious inquires only.
« Last Edit: May 05, 2016, 03:17:39 pm by Big Daddy Roth »
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1May 20, 2016, 05:49:59 pm
Big Daddy Roth
  • 298
Re: 1995 AAZ Passat Wagon
« Reply #1 on: May 20, 2016, 05:49:59 pm »
I missed a few things:
- Air bag delete / B3 glove box
- OEM Roof bars and cargo basket
- European headlight switch w/fogs
1993 TD B3 Sedan
Reply #2June 14, 2016, 04:44:45 pm
Big Daddy Roth
  • 298
« Reply #2 on: June 14, 2016, 04:44:45 pm »
Sold
1993 TD B3 Sedan
