Author Topic: New to Me 86 Jetta 1.6TD White Smoke  (Read 13951 times)
February 20, 2016, 07:08:48 am
curt5446
  • 21
« on: February 20, 2016, 07:08:48 am »
Hi all,
I just purchased an 86 Jetta turbo diesel from my neighbor for $800. He rebuilt the engine top to bottom, new injection pump, turbo, clutch, everything. The car has been idled and only driven down the street and back.
The car starts hard and pours white smoke out of the exhaust and is clacking (injector clack) rather badly. The engine smooths out slightly when I pull the advance cable but never runs well.  The smoke reeks of unburnt diesel.
In my experience with old OM617 Benz diesels this is either an injection pump timing issue or the injectors themselves. He replaced the injector nozzles however, did not have them pop tested or balanced.
Assuming he timed the pump correctly, I should be looking at injectors correct?
Any insight would be greatly appreciated!
Thanks!
Curt
'86 Jetta GL Sedan 1.6 TD 119k miles on the chassis engine rebuilt at 119k
Early 99 Ford F350 crew cab long bed dually 7.3 Powerstroke
1975 Mercedes 300D
Reply #1February 20, 2016, 04:42:09 pm
Re: New to Me 86 Jetta 1.6TD White Smoke
« Reply #1 on: February 20, 2016, 04:42:09 pm »
Sounds like the timing is probably way retarded or maybe even 180° out. I'd start by advancing it some (move the pump towards the head) and see how it reacts. Really though you should just treat it like it needs a timing belt job and start fresh - who knows what quality stuff is in there whether the tensioner was actually replaced, etc. Timing belt kits are cheap, head rebuilds are expensive!
Reply #2February 28, 2016, 08:07:22 am
air-cooled or diesel
« Reply #2 on: February 28, 2016, 08:07:22 am »
id be-wary of advancing pump, the 1 thing, the 'clacking' seems to indicate an advanced timing, already, the smooth out 'when' you pull cold start advance, doesnt mean timing isnt currently over-advanced. the injectors not being pop tested is 'a possible' problem, but your getting too much symptoms of what sounds like it may be an advanced pump. i tho have good exp in timing a motor. you need some timing tools. for a veedub 1.6; a socket +1/2 ratchet, cam lock+feelers, that will handle cam timing, check that 1st, then you need the dial gauge and adaptor, and get pump measurement @TDC. i dont have a lot of exp in a running motor,adjusting pump timing, but right now id say you need to be careful of an over-advanced timing right now, 1 thing some people have pointed out on a 'rough' timing setting, is with motor running adjust pump, try retarding where you are at now and try to find a good smooth running spot/curve, you ll have to loosen injector lines prob a couple of times doing this. if you know how to do it; but its more of an idea, or suggestion, if your not confident in your Diesel mechanic skills, i mean dont burn it up or lose something, cause your eager to jump in to this and if something goes wrong it can become a project. i mean your messing with the timing right now,
if you do a running timing 'try' id still suggest timing cam and pump with right tools before too long; in this case you dont have to loosen anything (at first) the 1st thing you want to verify cam and tdc, and then get a measurement on inj pump, and go from there.
not to say to do adjusting (of timing) you ll need to pull a few more tools out of your tool box, or otherwise be prepaired. as far as van suggestion of pump being 180d out, most pumps that are 180d out have two holes that can take inj pump timing lock. quik way to find out, find crank TDC, and with cam @TDC(also) slip pump lock in, that is the 'general' inj pump TDC, then after a few steps, you get to adjusting inj pump with a dial.
« Last Edit: February 28, 2016, 08:19:35 am by air-cooled or diesel »
Reply #3February 28, 2016, 05:43:17 pm
« Reply #3 on: February 28, 2016, 05:43:17 pm »
I would be inclined to advance the pump myself but don't we hear and see about the same symptoms from both a retarded and an advanced pump?  So knowing that these engines do OK in a retarded state I would follow Air-Cooled advice.
One thing I didn't see so much of was reference marks.  If you don't have the necessary tools before you just go loosening bolts and injection lines on the back of the pump clean the top of the IP and the bracket that it bolts up to.  Put a nice deep scribe line on it.  When we are talking about changing the timing in a significant manner we are talking a movement of milimeters on the IP.  Really, this is not the gas distributor thing.  Very small shifts in that IP from the rear or towards the engine itself makes a big deal of difference.
To check the One Hole- Two Hole pulley alignment to determine if the pump is 180 degrees out of time I would take my IP pulley tool, the 3/4 inch carriage bolt and line it up in the hole.  Then look at the keyway in the Pulley under the nut and see if it was towards the 10 o'clock position or at the 4 o'clock.  10 is where it should be.  That will tell you if you need to change a little or a lot of the setup.
Just thinking what a guy with some knowledge but lacking VW timing tools can do to try and fix this one.
Reply #4February 29, 2016, 05:11:04 am
« Reply #4 on: February 29, 2016, 05:11:04 am »
1thing i was considering was checking adjustment of pump as the guy you bought it from left it. you, (possibly with results), can look at base "front" of inj pump as installed; look at the base, the sliding"mechanism" where the 1 lock bolt both allows the adjustment and the bolt to lock the pump, if that slider looks farther to the one side than near the middle of the slider, i was thinking;.
but at the same time i was also thinking;;cause a new guy on a timing belt job, i--thru the years have lost at least 2 motors to timing belt failure, 1 time as i had just come out of hi-school, and beat howmany endless miles on an old '85, at that time an '85 or '85 wasnt that old/long ago, well getting a timing belt can at the least cost you in $/work&time, a head+all the parts, and maybe the whole motor, or other internal parts,  i  junked that car and another good 1; an old '84 mk1, d,na,hydro lifters,w/ac, 'e'5speed. yawn, was so long ago, and had how many 100ks miles, saw my sister thru college and longer. then i got it.
Reply #5March 03, 2016, 03:57:51 pm
curt5446
  • 21
« Reply #5 on: March 03, 2016, 03:57:51 pm »
Evidently I forgot to subscribe to this thread as I just realized there were a bunch of replies on it. Sorry for that.
To update, since my first post, I purchased an engine timing kit. Cam lock, IP lock, dial indicator with adaptor etc.
I checked cam, crank and injection pump timing. All of the timing belt bits were timed correctly. I reset the IP timing to 1mm as recommended in the Bentley. Still pouring white smoke. Installed Bosch rebuilt injectors (rebuilt by a Bosch certified shop) and still white smoke.
When I advance the pump now, it runs well and the cackle is gone but, I'm still not comfortable driving the car with the pump like that so, I found a known good used IP from a gentleman on here and will install that and see where we are.
I did just run out with my IP tool and verify my key is at the 10 o'clock position when the lock is in place so all is good there.
After researching the parts used for the rebuild, I found that the head and IP were purchased from Prothe. I contacted him and asked that he warrant the pump but, because my neighbor purchased the pump more than 2 years ago, he refused but, I have started dialogue with him about and will try to at least get an exchange.
So, I'm pointing fingers at the pump now.
1975 Mercedes 300D
Reply #6March 04, 2016, 01:42:30 am
« Reply #6 on: March 04, 2016, 01:42:30 am »
prothe pump would seem the most likely cause of your problems, probably be better if you decided to find a pump that works from somewhere else,, i bought a used pump form here,(forum), it needs some work, havent installed it yet, after some work in the spring i should install it; the old pump that came out had more than 800k on it, main seal decided it had enough and gave out, spilling some diesel on belt, and letting a lot of air in,,made it home, with all the mileage ive never been left stranded by a mk1 or mk2. just end up having to fix a few things a year,
Reply #7March 04, 2016, 06:19:23 am
curt5446
  • 21
« Reply #7 on: March 04, 2016, 06:19:23 am »
https://youtu.be/GPGkQ3mg-5Q
Here she is running after adjusting the pump while running. Sounds good to me but I'm used to Benz 5 cylinder diesels.
Sent from my HTC6535LVW using Tapatalk
1975 Mercedes 300D
Reply #8March 04, 2016, 05:32:18 pm
« Reply #8 on: March 04, 2016, 05:32:18 pm »
A Prothe pump could definitely be the cause of your problems! Who knows what bits are actually in it. I suspect the dynamic advance isn't working properly.
Reply #9March 06, 2016, 05:50:31 am
« Reply #9 on: March 06, 2016, 05:50:31 am »
I had a prothe pump back in 05 or 06, before the forums warned of his junk. He didn't even put the washers in the advance section where the spring is. It had probably 1/8 to 1/4 inch of slop before the advance engaged in either direction and impossible to time.
Reply #10March 26, 2016, 08:39:44 am
curt5446
  • 21
« Reply #10 on: March 26, 2016, 08:39:44 am »
Well, got a pump from a reputable source (Parts Place), it was rebuilt by a Bosch certified center near my house and drop shipped to me.
I installed it, got it running and, pretty much the same thing. Will not idle unless the cold start lever is pulled out, and still bellows white smoke. Moving the injection pump (retard/advance) doesn't help much. Runs a little better towards advance and stumbles like hell when retarded. It revs ok....still white smoke.
I doublechecked that the belt is in the correct position according to the Bentley manual.
Anything I can check/adjust? I'm ready to throw in the towel on this thing
1975 Mercedes 300D
Reply #11March 26, 2016, 09:50:53 am
curt5446
  • 21
« Reply #11 on: March 26, 2016, 09:50:53 am »
Timing plate in end of cam, both lobes of #1 are up.
Locking pin in pump.
Crank set to TDC.
Only thing I can think of is the flywheel is in the wrong position but, it wouldn't run at all if that were the case would it?
1975 Mercedes 300D
Reply #12March 27, 2016, 01:19:30 pm
« Reply #12 on: March 27, 2016, 01:19:30 pm »
Well you ruled out the poor quality, suspect quality IP out of the equation.  But did we run it off a container in the engine area compared to running from the tank?  Can't remember and thread is getting long.  Did you bottle feed it?
If you have done all that and are sure you are not pulling air into the system then perhaps there is a reference problem.
Only thing I would try to determine at this point is the reference of the TDC to actual TDC of the pistons.
Reply #13March 27, 2016, 01:26:17 pm
curt5446
  • 21
« Reply #13 on: March 27, 2016, 01:26:17 pm »
I have not done an under hood container yet. Thought of that as I was trying to fall asleep last night. Think I'll try that and if it does the same thing, pull the number 1 injector and see if the piston is there.
1975 Mercedes 300D
Reply #14March 27, 2016, 04:39:42 pm
« Reply #14 on: March 27, 2016, 04:39:42 pm »
Well, you did say it was a recent rebuild and I would hope that anyone taking four pistons out would replace them all and not give back only 75%.  Maybe a cost saving move?
