Author Topic: Oiling for compound turbos  (Read 3021 times)
February 20, 2016, 03:23:45 am
Ian0391
  • 119
« on: February 20, 2016, 03:23:45 am »
Hey guys,
I'm in the process of piecing together a compound turbo setup and I'm wondering about how I should run the oil lines. Do you think it would be better if I t'd off the main line and routed it to both turbos or should I run two seperate lines from the oil filter bracket. My oil filter housing has the hole for the turbo oil line plus two holes for pressure senders however I'm only using one so the other just has a plug in it. I could use that second one for a seperate line to the other turbo. Which would be best?
Sent from my SM-G920W8 using Tapatalk
Reply #1February 20, 2016, 04:44:50 pm
Re: Oiling for compound turbos
« Reply #1 on: February 20, 2016, 04:44:50 pm »
Extra tall banjo bolt and stack em would be my suggestion - use a couple universal braided oil feed lines. Or run to a fixed oil rail block with a couple ports on it. Avoid in line tees...
Reply #2February 20, 2016, 05:01:59 pm
Ian0391
  • 119
« Reply #2 on: February 20, 2016, 05:01:59 pm »
That's a good idea, and idea where I'd find an extra tall banjo bolt?
Reply #3February 20, 2016, 05:37:04 pm
« Reply #3 on: February 20, 2016, 05:37:04 pm »
Not sure off hand where but they are a common enough thing. Hydraulic supply shops would probably be a good source.
Reply #4February 20, 2016, 06:09:09 pm
Ian0391
  • 119
« Reply #4 on: February 20, 2016, 06:09:09 pm »
Cool, thanks man
