Author Topic: T3 turbo for parts  (Read 3662 times)
December 22, 2015, 06:52:47 am
mammonista
  • 58
T3 turbo for parts
« on: December 22, 2015, 06:52:47 am »
An old T3 turbo for parts or repair. The turbine blades and bearings work as they should. No nicks on the blades and the bearings are tight and no oil leaks. However the exhaust side housing will need work. Two exhaust manifold stud holes will need drilling and tapping. Four wastegate cover stud holes will need drilling or tapping  And the wastegate actuator housing is rusted (and busted) around the entire circumference.
But these things are pretty rare anymore and if you are looking for a turbo cartridge that has a lot of life in it you are in luck. $70 and you pay shipping.
If it doesn't fit force it. If it breaks it needed replacing anyway!
