Author Topic: Are turbo bolts 1 time use?  (Read 4296 times)
November 13, 2015, 05:42:53 pm
RunninWild
  • 609
« on: November 13, 2015, 05:42:53 pm »
My 4 bolts that hold the turbo to the manifold have fallen out after maybe 50km. Are these 1 time use? I didn't torque them but I did make them tight. I'm confused why they Are falling out? Can I use locktight? Or would that break down from the heat?
Reply #1November 13, 2015, 08:32:25 pm
Re: Are turbo bolts 1 time use?
« Reply #1 on: November 13, 2015, 08:32:25 pm »
They are not single use bolts, but they are very special bolts.  VW wants $15 apiece for them.  Despite their appearance, I believe they are stainless.  They are not magnetic.  I have never used loctite on them.  I use nickel anti-seize on them and torque them to spec (the spec is 33 ft-lbs IIRC).  I have never had one loosen on me.
Reply #2November 13, 2015, 08:37:55 pm
RunninWild
  • 609
« Reply #2 on: November 13, 2015, 08:37:55 pm »
Weird all 4 have came out and my turbo is just sitting on the manifold now. I think I got a few spare bolts sitting around cuz $15 is crazy! I didn't use a torque wrench but definitely put more then 33lbs on them. Its odd they came out so easily so fast. For now long they were on there youd think I had them finger tight.
Reply #3November 15, 2015, 05:40:58 am
jmaddocks
  • 75
« Reply #3 on: November 15, 2015, 05:40:58 am »
You asked about Loctite.  FWIW, 034 Motorsport has extreme-temp thread locker:
http://store.034motorsport.com/extreme-temp-thread-locker-turbo-rated.html
It's not cheap.  In fact, it's so expensive, I'd exhaust every other option first (no pun intended). But it's nice to know that products like that exist.
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #4November 15, 2015, 07:57:34 am
« Reply #4 on: November 15, 2015, 07:57:34 am »
Hi-temp permatex gasket sealer will probably keep em from vibrating out. I use it on exhaust pipes to keep the slip joints from rusting together.
The real question is what's happening... excess vibration, sloppy threads, or...?
Reply #5November 15, 2015, 09:38:56 am
Dakotakid
  • 1240
« Reply #5 on: November 15, 2015, 09:38:56 am »
....or, uneven mating surfaces.
Reply #6November 15, 2015, 10:58:24 am
« Reply #6 on: November 15, 2015, 10:58:24 am »
...improper torque.  It's hard to get to 33 ft-lbs with a 3/8" ratchet.
Reply #7November 20, 2015, 10:30:37 am
Blaizefed
  • 2
« Reply #7 on: November 20, 2015, 10:30:37 am »
Those $15 bolts cost so much for a reason. They are a special alloy designed to cope with the turbo and the exhaust manifold moving around as they expand and contract from heat.   It's worth at least trying to get a 2nd hand set of them.
Not to say it's a must, I got away with using 8 mm nuts and bolts on an Aaz a few years ago as it was all I had to hand and then forgot about it till after I had sold the car. But if your not in a massive rush, at least snoop around for a set of the real ones. They cost that much for a reason.
Reply #8November 20, 2015, 11:27:16 am
RunninWild
  • 609
« Reply #8 on: November 20, 2015, 11:27:16 am »
I found 4 old ones I had in my bolt pile. Gonna swap the head this weekend and I will torque them properly
Reply #9November 20, 2015, 12:03:45 pm
« Reply #9 on: November 20, 2015, 12:03:45 pm »
Make sure you have the downpipe/turbo properly braced to the block. If it's not braced it's not surprising that they rattled loose.
