Author Topic: AAZ power loss, idles and starts fine  (Read 6726 times)
Reply #15November 10, 2015, 08:55:05 pm
dontdoemyourself
  • 110
    • www.clearviewmt.com
Re: AAZ power loss, idles and starts fine
« Reply #15 on: November 10, 2015, 08:55:05 pm »
I have a t2 with a needle valve that is totally closed off, disconnecting the wastegate. I have messed with the wastegate arm in the past, I could have it misadjusted. I may uninstall my intercooler and see if that helps at all.. If it means anything, I might pick up an air research t3 and aluminum intercooler this weekend,  hoping to build with 360 bearing and keep it in a budget, but the goal is 15-17psi intercooled...
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #16November 10, 2015, 09:36:26 pm
« Reply #16 on: November 10, 2015, 09:36:26 pm »
Without a boost signal to the wastegate, that turbo shouldn't have any trouble producing more than 9psi regardless of whether or not the intercooler is in place.  Is your wastegate being held shut properly?  Are you properly fueled?  What are your EGTs?
Reply #17November 10, 2015, 09:54:05 pm
dontdoemyourself
  • 110
« Reply #17 on: November 10, 2015, 09:54:05 pm »
Egt's are topping out around 1250-1300 under full load going uphill, towing a load.. Going highway speeds 60-65 mph Under normal hard driving on flat roads more like 750-900. Coolant temps can get a little high in the heat.
I know Giles left me some more room to turn the max fuel up. And yes, as far as I can tell the wastegate is keeping it closed.. I preloaded it just a little..I may take my exhaust off to see if it is clean though. The t2 from what I've read can handle 16 psi or so, but for how long?
Reply #18November 11, 2015, 06:37:37 am
dontdoemyourself
  • 110
« Reply #18 on: November 11, 2015, 06:37:37 am »
Well, scratch that.. Engine blew up this morning.
Reply #19November 11, 2015, 07:27:34 am
« Reply #19 on: November 11, 2015, 07:27:34 am »
Wow, sorry to hear that.  What happened?
Reply #20November 11, 2015, 09:22:37 am
dontdoemyourself
  • 110
« Reply #20 on: November 11, 2015, 09:22:37 am »
Started to lose power going up a hill, then tried to downshift and it ran away a little, so I turned around and tried to limp 8 miles back home and made it about 2 before I totally lost power. Threw the number 4 rod. Through the block. When I tear it apart I'll be able to tell what happened for sure... Not sure where I can find a new long block..
