Author Topic: And then this fell out...  (Read 5882 times)
October 12, 2015, 05:06:46 pm
mapper
  • 4
« on: October 12, 2015, 05:06:46 pm »
Hi All,
This is my first post and I want to kick off by saying what a great resource I've found this site. I really appreciate the expertise and experience that's captured here.
My task, I'm rebuilding a 1.6 td JM engine. If successful, my plan it to put it in my jetta and pull the aaz from that for my van.
This is my first rebuild and I've hit a snag I want to fix before I bolting up the head, etc. During the tear down early in the year this guy dropped out the engine as I rotated it on the stand. Anyone recognize it? Can you tell me where it belongs?
Thanks,
Steve
mmh.. can't get image to display. h t t p s://flic.kr/p/yKFngE
« Last Edit: October 12, 2015, 06:01:20 pm by mapper »
Reply #1October 12, 2015, 05:45:02 pm
Re: And then this fell out...
« Reply #1 on: October 12, 2015, 05:45:02 pm »
try BB code
19 by sja_young, on Flickr
Reply #2October 12, 2015, 06:04:34 pm
mapper
  • 4
« Reply #2 on: October 12, 2015, 06:04:34 pm »
sorted... thanks!
Reply #3October 12, 2015, 06:28:17 pm
« Reply #3 on: October 12, 2015, 06:28:17 pm »
That's pretty weird right there. It certainly isn't a factory VW part. I don't think VW used a single nylock anywhere on the engine itself....
Reply #4October 12, 2015, 06:51:18 pm
« Reply #4 on: October 12, 2015, 06:51:18 pm »
I've pulled quite a few 1.6TD engines down to their most basic bits and have never seen that part.
Reply #5October 12, 2015, 07:53:02 pm
rallydiesel
  • 1880
« Reply #5 on: October 12, 2015, 07:53:02 pm »
Is that some kind of expansion plug? Definitely not a vw part as was mentioned already. I'd check the external oil passage bores and make sure the proper plugs are in place.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6October 12, 2015, 09:06:13 pm
mapper
  • 4
« Reply #6 on: October 12, 2015, 09:06:13 pm »
Thanks guys. I took it apart. It's not clear in the photo, but there's fine mesh on the nut and a spring a small bearing inside. Seems like its a tappet. I had thought it was associated with the intermediate shaft, but couldn't see how. I'll set it aside.
Cheers,
Steve
Reply #7October 13, 2015, 07:50:37 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #7 on: October 13, 2015, 07:50:37 am »
Hmmm.... spring and ball bearing inside sounds like a check valve. Perhaps some sort of over-pressure relief.
« Last Edit: October 13, 2015, 07:54:39 am by Rabbit79 »
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #8October 14, 2015, 08:07:02 am
Renxx
  • 1
« Reply #8 on: October 14, 2015, 08:07:02 am »
Pressure control valve from power steering pump..  Look for spring too!
Reply #9October 14, 2015, 08:16:48 am
« Reply #9 on: October 14, 2015, 08:16:48 am »
Nice.  How'd that get in the engine?
Reply #10October 14, 2015, 05:06:37 pm
  • 4549
« Reply #10 on: October 14, 2015, 05:06:37 pm »
Makes you wonder how well his power steering is working doesn't it?
Reply #11October 14, 2015, 10:56:50 pm
mapper
  • 4
« Reply #11 on: October 14, 2015, 10:56:50 pm »
Impressive bit of ID'ing.  Thanks Renxx
I pulled the rocker cover and oil pan before stripping down the engine... wanted to check the cam and crank before getting too much time into it. My guess is the spring  and Murphy's law did the rest when I disconnected the power steering hose.
Thanks again
