Author Topic: removing broken bolt from turbo  (Read 3694 times)
October 06, 2015, 05:22:29 am
moTthediesel
  • 194
« on: October 06, 2015, 05:22:29 am »
This is not IDI specific, but I thought it might help somebody out sometime:
I had to remove the VNT15 from my hydraulic 1.6 in order to do a head gasket job. I know I had used lots of anti-seize on those fasteners when I put it together only about 12k miles ago, but still, one of the 8mm bolts sheared right off when I put a wrench on it. On examination, it looks like the bolt had been cracked for some time, as you can see in this pic.
There was a good bit of the bolt exposed, and I could have just tried a vice grip on it, or maybe even two ground down nuts locked against each other, but I have a favorite technique in these cases. I found a larger hex nut that would drop over the bolt, in this case a 3/8". Then I sawed off the bolt so that it would extend about half way up into the nut, as you see here.
The I got out the MIG welder. I set the AMPs pretty high, as heat is the whole point here. I carefully filled the cavity in the nut with weld bead, then let it cool.
I put a socket on it then and turned it out, it came right out with ease.
There you have it -- no promises, but that trick has never failed for me.
Tom
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #1October 06, 2015, 06:52:09 am
RunninWild
  • 609
Re: removing broken bolt from turbo
« Reply #1 on: October 06, 2015, 06:52:09 am »
Thanks I have this exact problem but even less threads to work with. I'll give that a try.
Reply #2October 06, 2015, 09:28:02 am
« Reply #2 on: October 06, 2015, 09:28:02 am »
If it is flush/below the surface, you can use a fender washer instead with the appropriate ID to avoid welding to the surrounding metal.  Usually vice-grips on the OD of the washer works, but it is also possible to then weld a nut to the washer.
Reply #3October 06, 2015, 03:44:51 pm
« Reply #3 on: October 06, 2015, 03:44:51 pm »
I find the  mass of the   block/head  provides plenty of heat sink to keep the weld from buggering the threads even if its broke surprisingly far below flush.
I usually try to remove wile still pretty hot, theory being if the bolt is   still soft, it will conform to the threads.
