Author Topic: Head surface prep?  (Read 11720 times)
Reply #15September 27, 2015, 12:01:53 pm
RunninWild
  • 609
Re: Head surface prep?
« Reply #15 on: September 27, 2015, 12:01:53 pm »
Any opinion on copper spray? I cant seen to find hylomar anywhere.
Reply #16September 27, 2015, 01:52:28 pm
« Reply #16 on: September 27, 2015, 01:52:28 pm »
I always buy hylomar on the internet
Reply #17September 27, 2015, 02:36:52 pm
RunninWild
  • 609
« Reply #17 on: September 27, 2015, 02:36:52 pm »
Have a good supplier? Only places be found are almost $40 a bottle after shipping
Reply #18September 27, 2015, 03:05:19 pm
air-cooled or diesel
« Reply #18 on: September 27, 2015, 03:05:19 pm »
take a clean head bolt and see if all the block holes/threads are good, if with a ratchet like 1/2" you can run bolts down fairly easily and smoothly, your fine, ive never tapped the block, and used new head bolts too. 1st clean the threads with brake cleen and you can use qtips to get the threads final cleaned, get as much stuff out of the holes, and dry too, then anti-seize a bolt and run in down.
Reply #19September 27, 2015, 04:06:00 pm
Reply #20September 27, 2015, 05:15:36 pm
RunninWild
  • 609
« Reply #20 on: September 27, 2015, 05:15:36 pm »
Any problem with using the non aerosol stuff? That can plus shipping is over $45 to Canada. I can get the tube stuff for under $20. I know the tube is probably harder to get an even coat?
Reply #21September 27, 2015, 07:15:19 pm
Reply #22September 27, 2015, 07:22:07 pm
RunninWild
  • 609
« Reply #22 on: September 27, 2015, 07:22:07 pm »
It's $33 plus $16 shipping to Canada. Is that stuff worth almost $50 a can? I'll buy it if I have too but it's annoying when every little thing that should be $10 ends up costing closer to $50 when I have to deal with shipping to my stupid country!
Reply #23September 27, 2015, 10:17:30 pm
  • 4553
« Reply #23 on: September 27, 2015, 10:17:30 pm »
I have used the tube stuff as I found a NAPA store closing it out for 8 dollars a tube.  Not a problem getting a smooth coat on.
Reply #24September 28, 2015, 07:50:44 am
« Reply #24 on: September 28, 2015, 07:50:44 am »
I searched Canada ebay and it said 33 and free shipping. Try it yourself...find your ebay, amazon, whatever and search hylomar spray...that is if the one from the ebay.ca site isn't working for you.
Reply #25September 28, 2015, 04:51:21 pm
RunninWild
  • 609
« Reply #25 on: September 28, 2015, 04:51:21 pm »
It probably says free shipping because your in the states. When I goto that page it lists $13 shipping. I may have found a Canadian supplier. They said they dont stock the spray can but they have the tubes in stock. They are contacting hylomar to see if they can order some in.
Reply #26September 28, 2015, 09:33:00 pm
« Reply #26 on: September 28, 2015, 09:33:00 pm »
There's a Permatex gasket adhesive in a spray can available at Canadian Tire, it is about the same thing as Hylomar. A sticky gasket adhesive that permits some movement and is blue in color in an aerosol can.
Reply #27September 29, 2015, 07:57:34 pm
« Reply #27 on: September 29, 2015, 07:57:34 pm »
I have looked for generic hylomar and found nothing suitable. If it is the same make up let me know as I would love to find something as good but less money.
Reply #28September 29, 2015, 09:26:17 pm
« Reply #28 on: September 29, 2015, 09:26:17 pm »
The only Permatex spray I know of that I might call similar is the 'high-tack'.  The can is blue, the spray is more of a deep red.  It's quite a bit more sticky but might work similarly.  I think I'll stick with hylomar but that is an interesting thought as a backup.
Reply #29September 29, 2015, 09:49:33 pm
« Reply #29 on: September 29, 2015, 09:49:33 pm »
Actually you're right, the spray is red... Well on the upside it's pretty readily available, at least here in Canada.
