TDI - Pumpe Duese TDI Engines
Oil Grade
Topic: Oil Grade (Read 14600 times)
September 07, 2015, 06:07:57 am
wpoggyer
Newbie
Oil Grade
September 07, 2015, 06:07:57 am »
I have a 2.0 170 touran which is DPF removed and remapped, now I have taken out the DPF, can I get away with a normal 5/30 oil or is the PD low ash oil still needed to stop cam wear?
September 08, 2015, 09:00:25 am
Re: Oil Grade
September 08, 2015, 09:00:25 am »
I'm guessing that's a common rail engine, so PD style cam wear is not an issue. There's a thread over on TDIClub about this exact subject; you should be able to run a normal synthetic DIESEL RATED oil (API-CJ4 rating) safely, such as Rotella T6.
September 10, 2015, 01:04:03 pm
wpoggyer
Newbie
Re: Oil Grade
September 10, 2015, 01:04:03 pm »
Thanks for the reply, I will have a look on the TDI club forum.
Oil Grade
