Author Topic: Whats involved in a frankenengine?  (Read 3321 times)
August 30, 2015, 03:35:06 pm
RunninWild
  • 609
« on: August 30, 2015, 03:35:06 pm »
I cooked the headgasket on my 1.6td and am thinking of throwing on my new AAZ head I've been saving for the engine I'm building. Is the AAZ head taller then the 1.6? Do I use the 1.6 timing belt and injection pump/lines/injectors? Anything special I'd need to consider? I know itll be harder starting in cold weather but I'd rather not spend anymore money on this 1.6 when I've got a new aaz head sitting around.
Reply #1August 30, 2015, 04:21:19 pm
Blocksmith
  • 261
    Wrench Lurker
Re: Whats involved in a frankenengine?
« Reply #1 on: August 30, 2015, 04:21:19 pm »
Lots of info on this site already about franken 1.6s, but the quick rundown of relevant differences are: it's only a direct bolt on for a hydraulic lifter block 1.6, and the intake ports are D-shaped instead of round. The valve cover is different as well, if you don't already have that.
The block is what's taller on the AAZ, not the head. You would use all your existing 1.6 fuel system stuff, and a 1.6 timing belt.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #2August 30, 2015, 05:54:12 pm
RunninWild
  • 609
« Reply #2 on: August 30, 2015, 05:54:12 pm »
Great thanks! I think I should have everything I need other then gaskets and bolts.
Reply #3September 04, 2015, 06:53:53 pm
RunninWild
  • 609
« Reply #3 on: September 04, 2015, 06:53:53 pm »
Would it be better to run my giles AAZ pump with a k24 or would it not make much difference over the 1.6td pump?
Reply #4September 04, 2015, 07:26:29 pm
« Reply #4 on: September 04, 2015, 07:26:29 pm »
Definitely run the Giles pump...
Reply #5September 05, 2015, 07:16:36 am
RunninWild
  • 609
« Reply #5 on: September 05, 2015, 07:16:36 am »
Just to clarify the aaz pump would still use the 1.6 timing belt, injector lines and injectors? Or would I have to bend the injector lines a bit? I havn't directly compared a 1.6 vs 1.9 pump but Its always looked like the 1.9 was a bit larger.
Also what would be the best place to start with timing the pump?
« Last Edit: September 05, 2015, 07:21:24 am by RunninWild »
Reply #6September 05, 2015, 08:44:33 am
« Reply #6 on: September 05, 2015, 08:44:33 am »
The AAZ pump will fit without issue provided it is the one-piece sprocket and you use that AAZ sprocket and late 1.6 metal lines (89+?) and injectors.  You can also use the earlier metal lines but would need to replace the long AAZ delivery valves with the shorter early 1.6 delivery valves.
