Author Topic: My 1.6TD Compound Turbo is up and running, 30psi of boost in neutral!  (Read 37159 times)
Reply #30September 02, 2015, 06:35:03 am
Alcaid
  • 549
Re: My 1.6TD Compound Turbo is up and running, 30psi of boost in neutral!
« Reply #30 on: September 02, 2015, 06:35:03 am »
Anyone seen the movie "The Pinchcliffe Grand Prix"?  ;)
'10 VW Passat 1.6TDI Highline
Reply #31September 02, 2015, 11:04:41 am
Selle
  • 9
« Reply #31 on: September 02, 2015, 11:04:41 am »
Short video from me. Not from the track, but som testing in the middle of the event
https://youtu.be/T6zJEtXzS88
Reply #32September 04, 2015, 11:44:22 am
golfmk1tdr
  • 53
    • My car's forum thread
« Reply #32 on: September 04, 2015, 11:44:22 am »
This is awesome :) Scaring the sheit out of drivers behind you because they cannot see through smoke
and when it clears- you are gone   8)
I find it interesting that you even have smoke at such boost levels   ;D
Your injectors are stock GTD I quess?
What is your max EGT you saw on this setup?
I always wondered what is the limit with IDI diesel with your headwork, valves and everything..
I believe you achieved it  :P
What is you tire brand and tire size? I plan on federal rsr 195/50 but your look like more ''meat'' and different profile...
Almost drag racing-fat haha loving it!
Keep up great work!
1.6+holset MK1 Golf TDR /TurboDieselRacing
(no GTD because GT is grand tourismo and there is nothing grand and touristic in my stripped out lowered beast)
Reply #33September 04, 2015, 02:24:26 pm
Alcaid
  • 549
« Reply #33 on: September 04, 2015, 02:24:26 pm »
185/60-13 Yokohama A048  track/competition tires ;) Wanted to keep the 80s look on the car. Pump delievers a ***load of fuel, will up the boost soon
Reply #34September 04, 2015, 02:28:47 pm
Alcaid
  • 549
« Reply #34 on: September 04, 2015, 02:28:47 pm »
Fratelli Bosio GTD nozzles on AAZ two stage injectors. Didn't have time to hook up the EGT gauge so will have to check that in the dyno. But it's easy to cool down the EGT with addee boost if needed since I am running compounds. ;)
Reply #35September 09, 2015, 06:23:29 am
jmaddocks
  • 75
« Reply #35 on: September 09, 2015, 06:23:29 am »
Holy crap, that's awesome.
Fantastic job, Petter.
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #36September 09, 2015, 08:36:44 am
« Reply #36 on: September 09, 2015, 08:36:44 am »
it is truly impressive, if it can dyno the 300whp that is like a 5.9L cummins turbo diesel making well over 1000hp
Reply #37September 12, 2015, 09:54:20 am
CrazyAndy
  • 739
« Reply #37 on: September 12, 2015, 09:54:20 am »
Wow I never knew they let freight trains run on the track, because that thing HAULS!!  What an amazing setup.  I've never seen an IDI this massively built before.  I've seen some great high-flow single turbos (shout-out to theman53!), but no one runs compound around here outside of trucks.
On another note, Rudskogen looks like a very fun track!  I've heard it from mentions of the motorsport event Gatebil.  How is driving on it?
Reply #38September 12, 2015, 05:03:24 pm
Gizmoman
  • 1301
« Reply #38 on: September 12, 2015, 05:03:24 pm »
That's nuts Alcaid - I didn't know a turbo could even boost at idle.
Still loving my Holset
Reply #39September 14, 2015, 12:26:07 pm
Alcaid
  • 549
« Reply #39 on: September 14, 2015, 12:26:07 pm »
Rudskogen is a demanding track for both car and driver. You need lots of HP to drive fast, lots of guts to brake late even approaching blind turns and a challenging track, but it is very fun! :) I am more comfortable in my Golf 4Motion PD130 (now 191awhp) on tracks so need to drive more with this Jetta to get comfortable with FWD, lower weight, no power steering, poor brake assist etc. etc.
What's better than a Holset, right? ;) (The answer is TWO Holsets!)
Reply #40August 05, 2016, 01:40:55 am
Alcaid
  • 549
« Reply #40 on: August 05, 2016, 01:40:55 am »
Long time no update on this project as I got really sick and tired of it....
I initially had some head studs made from the Finnish guy that calls himself AKI-76. They stretched and all came loose on initial test driving... Tried to re-torque and they started stretching  real bad and one broke.... Tried saving the head gasket by changing out one and one stud with ARP but gasked was blown. Later I changed the head gasket but was still blowing coolant out of the expansion tank (running 60psi of boost on the last tests with great power and low back pressure!). Took a long break from the project as I was really sick and tired of it....
Finally got the interest to continue the project and took the head of again to pressure test it and resurface if necessary. Head was warped on cylinder #2 and #3 so really in need of a resurfacing. Will get the engine back together again soon and do further testing on 60psi of boost.
Pic showing the head after the first pass, easy to see why I had coolant blowing out of the expansion tank!
finally head is flat again!
Reply #41August 12, 2016, 09:34:29 pm
  • 2932
« Reply #41 on: August 12, 2016, 09:34:29 pm »
 Do you line bore the cam when you surface the block?
Center journals are going to be high and make the cam teeter totter.
Reply #42August 14, 2016, 10:55:44 pm
Alcaid
  • 549
« Reply #42 on: August 14, 2016, 10:55:44 pm »
Not done anything to them, not had to do that before either when surfacing a head...
Reply #43August 15, 2016, 06:02:27 am
« Reply #43 on: August 15, 2016, 06:02:27 am »
any opinion about resurfacing with the prechambers still in place?
Reply #44August 15, 2016, 04:41:57 pm
« Reply #44 on: August 15, 2016, 04:41:57 pm »
I thought it weird.  But apparently it didn't do they any harm.  Just a few thousands less for wear.   I wouldn't expect a problem unless they were loosened in the process and not tapped tight to prevent being blown out now.
« Last Edit: August 16, 2016, 08:49:31 pm by ORCoaster »
