Author Topic: Timing belts  (Read 4571 times)
August 18, 2015, 07:35:59 am
92EcoDiesel Jetta
Timing belts
« on: August 18, 2015, 07:35:59 am »
I've read t he current crop of Continental timing belts for the 1.6 are junk. I've got one on my 92 currently. Anyone have had bad experience with them? I've heard Gates makes a good belt. In searching the web I found this guide http://www.gates.com/~/media/files/gates/automotive/catalogs/automotive/timingbeltreplacementguide.pdf?la=en which shows our MK1 and MK2 belts to be a Gates T043.
Further search for Gates T043 I find that you can have it shipped free to a Walmart store near you for pickup. I didn't know you can order parts via Walmart's website! I am going to give them a call to see what the deal is.
http://www.walmart.com/ip/42689569?wmlspartner=wlpa&adid=22222222227031071046&wl0=&wl1=g&wl2=c&wl3=68363925048&wl4=&wl5=pla&wl6=96157700208&veh=sem
« Last Edit: August 18, 2015, 07:56:37 pm by 92EcoDiesel Jetta »
Reply #1August 18, 2015, 03:17:11 pm
rs899
  • 647
Re: Timing belts
« Reply #1 on: August 18, 2015, 03:17:11 pm »
I have had nothing but good news out of Conti belts for 20 years, but the last one I put on was 4 years ago.  I am about to spin up a Mitsuboshi on my 1.6 rebuild.  Don't know how it will work but seems to be a lot stiffer that Conti.  They are an OEM to a lot of Jap cars.
Reply #2August 18, 2015, 06:24:01 pm
turboedbug
  • 57
Re: Timing belts
« Reply #2 on: August 18, 2015, 06:24:01 pm »
What about a good quality tensioner? Or are the chinese knock offs decent
Reply #3August 18, 2015, 06:35:10 pm
Re: Timing belts
« Reply #3 on: August 18, 2015, 06:35:10 pm »
I've never heard anything bad about Continental timing belts myself.  Gates is fine though... my last T-belt on my 1.6 was a Continental, no problems.  My current t-belt on my TDI is a Gates.
DO NOT USE CHINA KNOCKOFF TENSIONERS!!!!  The belt itself rarely fails (unless it's a Rothenberger Engineering one), it's the tensioner that causes problems.
Litens is a common good quality manufacturer of timing belt tensioners.
Reply #4August 18, 2015, 06:41:27 pm
turboedbug
  • 57
Re: Timing belts
« Reply #4 on: August 18, 2015, 06:41:27 pm »
Ya thats what I assumed about the tensioners
Reply #5August 18, 2015, 08:02:15 pm
turboedbug
  • 57
Re: Timing belts
« Reply #5 on: August 18, 2015, 08:02:15 pm »
How bout swag tensioners or skf
Reply #6August 19, 2015, 12:56:49 am
Re: Timing belts
« Reply #6 on: August 19, 2015, 12:56:49 am »
SKF is fine. Haven't heard of Swag personally.
Reply #7August 19, 2015, 07:50:22 am
92EcoDiesel Jetta
Re: Timing belts
« Reply #7 on: August 19, 2015, 07:50:22 am »
Any comments on timing belts from Walmart online? There was a problem with font size being too small as to be illegible which I corrected. I called Walmart online customer service and was told as best they can tell, they get the belts directly from Gates.
Reply #8August 19, 2015, 08:39:19 am
Re: Timing belts
« Reply #8 on: August 19, 2015, 08:39:19 am »
If it is an authentic Gates belt that has been properly handled, as far as the belt goes, it doesn't matter where you get it.  That said, your dollar is your most powerful vote.  I prefer to vote for companies that actually support my vehicles rather than companies that get off on selling cheap crap to the sleeping masses.  YMMV.
Reply #9August 20, 2015, 10:19:53 am
air-cooled or diesel
Re: Timing belts
« Reply #9 on: August 20, 2015, 10:19:53 am »
about the only thing I buy at wallymart is maybe rotella(break-in for me), a/c charge, washer fluid, or sea foam, id tend to stay away from anything else,, try napa for gates belts, better quality and handling of product. napa's v-belts & serpentine belts are gates, for a better price than other places(usually). although prices of rubber have gone up significantly in recent. napa filters are wix, I don't know yet if napa fuel filters are wix. pay somemore for a better product(if even the same name,,)
