Author Topic: AHU/1z mtdi injector pipe query  (Read 4434 times)
August 01, 2015, 04:37:51 am
coleman262
  • 1
« on: August 01, 2015, 04:37:51 am »
Hi all, i run an mtdi converted mk2 golf van
spec is landy 200 pump
holset hx25 turbo
.240 injector nozzles
etc etc..
now im having some issues with the number 3 injector line, its just fractured/broken.
probably because the line has been bent as the injector doesn't have the sensor on it so its too high.
got a new line and bent it temporarily to keep me moving, but my question is,
is there a spacer, or a line that fits a standard height injector maybe from another engine? i dont really want to go to the hassle of getting another injector and getting the nozzles swapped.
Reply #1August 01, 2015, 09:59:31 pm
Re: AHU/1z mtdi injector pipe query
« Reply #1 on: August 01, 2015, 09:59:31 pm »
I have bent many lines without issue.  In fact, the only lines that I have had crack were ones that were not bent.  The important thing is to make sure the line fits exactly without coercion before tightening the union.
I do not know of any fitting available to take the place of the taller injector.  If you want not to bend the line, then I'd recommend fitting the taller injector.
« Last Edit: August 01, 2015, 10:01:10 pm by libbydiesel »
