Author Topic: Golf gtd [sb] cold start lever  (Read 2357 times)
July 26, 2015, 11:14:06 pm
dave friday
  • 122
« on: July 26, 2015, 11:14:06 pm »
Morning all,what does the cold start mechinisum on the pump do?does it have a fuel cut off?
Ta,Its 32deg c at 08.15!!
1992 1600 td syncro camper
Reply #1July 27, 2015, 06:51:59 am
Dakotakid
  • 1240
Re: Golf gtd [sb] cold start lever
« Reply #1 on: July 27, 2015, 06:51:59 am »
Cold advance = 3 degree advance I seem to recall.
Mechanical shut off????? No. The fuel pumps fitted to the old automatic trans had a little "arm" which you could rotate with your fingers to shut the engine off (after you lift the hood/bonnet/whatever).
Reply #2July 27, 2015, 07:48:03 am
dave friday
  • 122
« Reply #2 on: July 27, 2015, 07:48:03 am »
Thanks,i'm trying to find out why the engine is hard to start and only runs for 1 to 2 seconds after it does start.
The engine runs fine with the jx pump fitted..
