Author Topic: franken mTDI pump HELP!  (Read 16388 times)
July 08, 2015, 04:27:59 pm
vw offroader
  • 5
« on: July 08, 2015, 04:27:59 pm »
Hello everyone, I am new to the vw forum and am in the midst of pulling out my hair with this mTDI pump. I hope someone on here is able to help as the information I have been reading is great! Okay, so I have a 1999 ALH that the pump went bad on and decided to convert the engine over to mechanical for use in my rock crawler project. I had a diesel mechanic use a Bosch VE pump and swap out the head, Cam plate, and plunger. After putting the pump on the engine I tried to start it and the first time it ran it was running around 3500 rpms and had no throttle control. I was frustrated and let the pump / project sit for a couple months. After getting the project started again I can't get the motor to run.
     So I pulled the pump off and took it to pro-formance diesel injection service in Clearfield, PA. The guys up there are great to work with and are a certified Bosch rebuilder. The problem is they rebuilt the pump and put it on the stand for testing / tuning. The same thing happened to them. Everytime they run the pump it just takes off and has infinite running like there is no end. To the best of my knowleadge it still has no throttle control. Has anyon ever experienced this before? I am stranded at this point.
Reply #1July 08, 2015, 09:04:54 pm
Re: franken mTDI pump HELP!
« Reply #1 on: July 08, 2015, 09:04:54 pm »
what pump did he start with? Bosch ve...yes, was it an electronic gov. pump? was it an IDI pump? If he tried the E pump there is no real way to control the fuel pedal mechanically.
Reply #2July 08, 2015, 09:17:54 pm
« Reply #2 on: July 08, 2015, 09:17:54 pm »
Would be really helpful to know what various pump bits have been put together. There's hundreds of variants of the Bosch VE pumps all meant for different things.
The simplest thing to do would be to get a pump that just works, like a Land Rover 300TDI one. They don't need any internal modification to run an ALH.
Reply #3July 09, 2015, 10:16:00 am
vw offroader
  • 5
« Reply #3 on: July 09, 2015, 10:16:00 am »
Thanks for the responses. The original donor pump was from the 99 TDI ALH. Took the internals out of it and put it into the VW IDI pump. I believe the pump is off a 1.6. I should have wrote down the number off the pump and checked it to be exact. The ve pump does have the throttle linkage on top and has no wires. Just one to the stop solenoid. Like I said I am a newby at this. The pump is still at the rebuild shop and I am trying to get a hold of original diesel guy that I got the pump from to see where he acquired it. Is there any place on the internet that gives you the breakdown by number the original use of the VE pump?
Reply #4July 09, 2015, 08:33:39 pm
« Reply #4 on: July 09, 2015, 08:33:39 pm »
pretty sure the lever won't be long enough to really fuel unless you weld a piece on. Why it is revving and not coming down I have no clue
Reply #5July 09, 2015, 10:06:09 pm
« Reply #5 on: July 09, 2015, 10:06:09 pm »
Yeah those parts are anything but plug and play. Ugly. You could have sold the ALH and 1.6 pumps and bought a proper DI pump...
Reply #6July 10, 2015, 08:52:15 am
« Reply #6 on: July 10, 2015, 08:52:15 am »
You probably could have spent less and gotten a similarly non-working pump from Hans instead...   :P
There is a significantly steep learning curve to building a properly functioning franken mTDI pump.  Most folks (even certified Bosch rebuilders) do not have the knowledge/experience to pull it off.
All of that said, if the engine is running away right off the bat, then the most likely culprit is the accelerator lever to shaft orientation.  Undo that, let the shaft relax to idle, install the lever so that it is very close to idle.  Usually that is within one click of the correct position.  It should at least run there although possibly you will need to depress the accelerator to keep it idling.
Reply #7July 10, 2015, 01:22:36 pm
vw offroader
  • 5
« Reply #7 on: July 10, 2015, 01:22:36 pm »
Okay so I did some digging and the pump that they swapped the parts into was a 1.6 td not the IDI as I had originally thought. Are there any other mods that need to be done to the pump internally that I might have missed besides swapping just the 1.9 cam plate, plunger, and head? Does the governor have anything to do with the idle running away?  Also, I read that a rover 300 pump will bolt right on. If that is the case is this the pump they are referring to? http://www.roverparts.com/Parts/ERR4046
Reply #8July 11, 2015, 02:39:20 pm
« Reply #8 on: July 11, 2015, 02:39:20 pm »
1.6td = IDI.
Yes, there's modifications to the governor lever needed to make it work right.
Yes, that's the Rover pump that definitely works.
Reply #9July 12, 2015, 04:56:43 pm
vw offroader
  • 5
« Reply #9 on: July 12, 2015, 04:56:43 pm »
Thanks for the info. The wires on top of the rover pump, what are they used for? Cruise control??? I also read that you need to swap the nozzles from the alh to the rover 300 in order to use the stock vw injector lines. Is that true?
Sorry for so many questions, you guys are very knowledgeable. I'm just trying to figure it all out.
As far as the governor mods on the 1.6 frankenpump, do I need to shim between the springs, or change springs, or weld something? Any info is great. Thanks
« Last Edit: July 12, 2015, 06:06:34 pm by vw offroader »
Reply #10July 15, 2015, 09:03:13 pm
« Reply #10 on: July 15, 2015, 09:03:13 pm »
The wires on the Rover pump are used to control EGR on the Rover but do nothing on a VW. It's a throttle position sensor. I'm using mine for my VNT controller personally but the whole thing can be removed.
The delivery valves are too long, you can bend the injector lines to fit but swapping VW delivery valves is much easier.
The frankenpump needs welding probably. There's an old mtdi how to post on here somewhere that explains it.
Reply #11July 15, 2015, 09:09:07 pm
« Reply #11 on: July 15, 2015, 09:09:07 pm »
As I mentioned previously, if it is revving up uncontrollably then it is most likely because the accelerator lever to shaft orientation is not correct (or the max fuel screw is too far in).  Try turning the max fuel screw out a couple turns or jump the lever 1 click CCW relative the shaft.
Reply #12July 16, 2015, 12:55:07 pm
vw offroader
  • 5
« Reply #12 on: July 16, 2015, 12:55:07 pm »
Thank you vanbcguy and libbydiesel. I find all of this information helpful. I will be sure to look through the post to find the "mtdi how to post"
Reply #13July 17, 2015, 05:04:19 am
« Reply #13 on: July 17, 2015, 05:04:19 am »
I would have hoped a bosch service center would have found that? Did they even test it?
Reply #14December 10, 2016, 02:28:21 pm
nk14zp
  • 1
« Reply #14 on: December 10, 2016, 02:28:21 pm »
http://vwdiesel.net/forum/index.php/topic,6427.30.html  the good info starts around post 40.
