Author Topic: Aftermarket Tach  (Read 2310 times)
April 04, 2006, 02:34:43 pm
Op-Ivy
  • 513
Aftermarket Tach
« on: April 04, 2006, 02:34:43 pm »
My '90 TD came with the clock instead of the tach...... Is it prewired for a tach? If so which wire is it in the cluster?
Reply #1April 04, 2006, 04:42:12 pm
hillfolk'r
  • 1532
Aftermarket Tach
« Reply #1 on: April 04, 2006, 04:42:12 pm »
ive got a 91 non td,,i do know the "w " lead is back up there in the dash,,,,mayneed a different printed circuit,from a td tach dashboard,,,,,i raninto that,,ihave a 86 td tach,,and wanted toput in my 91 cluster,,,could add the wiring ontothe circuit,may be cleaner if you get correct printed circuit,,or get a whoile cluster w/ tach,,i bet it plugs+plays
Throttle cables ftw
Reply #2April 05, 2006, 01:42:41 am
regcheeseman
  • 714
Aftermarket Tach
« Reply #2 on: April 05, 2006, 01:42:41 am »
I've got a A2 GTD set of clocks if anyone is interested? - should plug and play no bother.
I'm in the UK so maybe shipping will be too much?
