VWDiesel Blog
Facebook Group
VWD on Twitter
Rover 200/300 compared to a Giles Super Pump.
Topic: Rover 200/300 compared to a Giles Super Pump. (Read 1668 times)
June 25, 2015, 04:11:14 pm
heywier427
User+
June 25, 2015, 04:11:14 pm »
Read that the Rover 200/300 is capable of 175hp +/-.
Is there really a need to have Giles pump built?
Modifying the Rover pump to fit into the 1.6 block does not sound difficult at all.
I am a noob. What am I missing?
Thanks.
June 25, 2015, 05:04:12 pm
Re: Rover 200/300 compared to a Giles Super Pump.
June 25, 2015, 05:04:12 pm »
The LR pump is specifically suited to direct injection engines. With one fitted to a 1.6, the aggressive timing advance, 11mm plunger and more abrupt camplate profile would all make for a VERY rattly engine.
June 25, 2015, 11:13:53 pm
Administrator
June 25, 2015, 11:13:53 pm »
Yup. You need a pump set up for what you're running. The Rover pump works on TDI engines due to both engines being designed for the same Bosch injection system. An IDI is a different animal.
