Author Topic: 91 Eco diesel Jetta AC question  (Read 5807 times)
June 24, 2015, 09:39:34 pm
DAKOTAKIDD
  • 114
« on: June 24, 2015, 09:39:34 pm »
Hey guys,  I am looking at charging my air conditioning system for the summer.  I know you charge through the low pressure port.  My question is which one is the low pressure port?   On top of the radiator or near the firewall/air box area?
Let me know
Thx in advance!!!
Sent from my i-thingy
Reply #1July 20, 2015, 05:07:50 pm
mk2jetta86
  • 5
Re: 91 Eco diesel Jetta AC question
« Reply #1 on: July 20, 2015, 05:07:50 pm »
Would be the smaller ports of the two and on our cars that still have the 1/4" thread connections. One you want us one closest to the expansion valve.
Reply #2July 20, 2015, 05:09:42 pm
DAKOTAKIDD
  • 114
« Reply #2 on: July 20, 2015, 05:09:42 pm »
Thx!!!
Reply #3July 20, 2015, 07:13:02 pm
mk2jetta86
  • 5
« Reply #3 on: July 20, 2015, 07:13:02 pm »
No problem
Reply #4July 23, 2015, 10:50:32 pm
air-cooled or diesel
« Reply #4 on: July 23, 2015, 10:50:32 pm »
if you have the newer refrigerant, the r134a the low port(s) is obvious, the port(s) should take only 1 size, the low side is also easily found, you cannt tell from the outside the flow of the system, but the bigger pipe is the return to the compressor, this line will or should have your lo-side port, like i said, if system has been upgraded the port should fit 1 size, the low-side,, if its r-12, the old set-up, from factory Becareful, both ports are the same size, look for the return pipe, the bigger one.
Reply #5July 23, 2015, 11:04:16 pm
« Reply #5 on: July 23, 2015, 11:04:16 pm »
becareful, i hope you have air-conditioning training, use safety procedures, safety glasses, no heat near anything a/c, note the face of the gauges are the most likely weak point, plastic can ruin your face or eyes, thats 1 reason i said wear safety glasses, make sure your stuff, like gauges+hoses,etc, are in good shape, snug all connections and check, as my gauges have multiple connections, and valves too, check all 1st, becareful those cheap(er) bottles i find in wallymart, dont use to charge; 1st: dont use a bottle with stop leak in, or says it seals leaks,,i like the black more expensive bottle A/C PRO or something, as the (2nd)cheap(er) bottles have cheap(er) hose&gauge, a little dangerous.
