Author Topic: 1991 gtd wiring diagram  (Read 2302 times)
June 24, 2015, 01:46:35 am
dave friday
  • 122
« on: June 24, 2015, 01:46:35 am »
Hi all,anyone got a wiring diagram [circuit diagram] for the above that they could pm me?
Ta.
1992 1600 td syncro camper
Reply #1July 01, 2015, 03:08:47 pm
smutts
  • 720
    ClackClackClackClackClack
Re: 1991 gtd wiring diagram
« Reply #1 on: July 01, 2015, 03:08:47 pm »
Nothing that makes sense, but what wiring issues are to trying to sort out? As I have my dead 1991 GTD outside.:) My guess is your Turbo coolant pump not running?
« Last Edit: July 01, 2015, 03:12:31 pm by smutts »
Reply #2July 01, 2015, 03:35:43 pm
dave friday
  • 122
« Reply #2 on: July 01, 2015, 03:35:43 pm »
Hi Smutts,I have a sb that I'm getting ready to replace the very poorly jx,I want to know if the sender on the water pipe on the Middle of the head is connected to the water temperature  gauge and the glow plug system,the other sender I guess is for the aux water pump .
Ta.
Reply #3July 02, 2015, 01:56:56 pm
smutts
  • 720
« Reply #3 on: July 02, 2015, 01:56:56 pm »
Okay, here goes, the two temp senders on the water outlet elbow in the front middle of the head, both are identical, one runs the temperature gauge, the other goes to the glow plug timer relay. The electrical turbo coolant pump is switched from a brass temperature switch on top of the turbo.  ;)
Reply #4July 02, 2015, 02:21:39 pm
dave friday
  • 122
« Reply #4 on: July 02, 2015, 02:21:39 pm »
Ta ever so much,i didn't think to look there!!
