Author Topic: 1983 Vanagon Diesel Accelerator Cable too short!?  (Read 3102 times)
June 13, 2015, 09:46:32 pm
Jimbo228
  • 1
« on: June 13, 2015, 09:46:32 pm »
Hello everyone. I am working my way through some upgrades to my diesel van that has a 1.6TD swap. I purchased it last year and she has certainly been a hobby! I am in the process of swapping on a Giles pump. He sent me with the proper arm, however as you see from the pictures I am about an inch too short.
The first picture shows the stock pump, however the former owner "fabed up" a new arm which confuses me because since it is the NA pump shouldn't the accelerator cable reach?
I plan to replace the cable but can't figure out where to find one for an '83. everything on the net say '82 deisel only. 3945mm, 155.31"
Does any one know why the cable does not reach the stock arm?
Does anyone know what length I need. Or what I should do? I feel like maybe it is already a replacement and maybe not the correct cable.
The second pic is with the new pump. It appears as if the cable was an inch longer it would fit both pumps.
Any help would be a amazing. I am trying to learn as much as possible in a short time. The rabbit hole is deep and Its just time to get out and go camping.
Cheers my friends!
PS How do I attach images?
Reply #1June 17, 2015, 05:46:29 pm
Syncroincity
  • 727
Re: 1983 Vanagon Diesel Accelerator Cable too short!?
« Reply #1 on: June 17, 2015, 05:46:29 pm »
Diesel Vanagon cables should be all the same, regardless of year. Possible that the fuel lever is clocked too far aft?
Most non-vanagon fuel levers will interfere with the engine cover, that's why you get home-made ones... it has to be bent over to mirror the tilt of the engine so it won't hit the cover.
Here's where I got mine; GEMO cable...
http://www.justkampers.com/vw-vanagon-parts/t25-pedals-cables-levers/accelerator-cables-fittings/251-721-555-g-accelerator-cable-vw-t25-left-hand-drive-diesel-1980-1992.html
To attach photos, you have to store the pictures on a hosting website, like Photobucket, Imgur, thesamba etc. then just do a copy of the address, and paste it into your post then have it highlighted and click the photo tab in the upper menu and it will add the image tags automatically.
« Last Edit: June 17, 2015, 05:52:19 pm by Syncroincity »
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2June 26, 2015, 11:59:27 pm
« Reply #2 on: June 26, 2015, 11:59:27 pm »
There are two diesel vanagon accelerator cables.  The '82 is part number 251721555C and is 3945mm.  The '83+ is part number 251721555s and is 3980mm.
http://www.busdepot.com/251721555s
http://www.ecstuning.com/ES327251/
