S-PAutomotive.com
Author Topic: Clutch slips at about 12 psi  (Read 3545 times)
June 06, 2015, 12:14:13 am
bryanb
  • 25
« on: June 06, 2015, 12:14:13 am »
Well I need a new clutch but can't find anything better than stock for a 1.6 TD FF code trans so please point me in a direction? I plan on building the engine including internals as much as possible so strong is key.
Don't be retarded a glow plug is nothing like a spark plug
Reply #1June 06, 2015, 11:14:57 am
  • 7837
Re: Clutch slips at about 12 psi
« Reply #1 on: June 06, 2015, 11:14:57 am »
Upgrade to a 210mm flywheel and clutch. If you are going for bunches of more power look for a company called Clutchnet. Don't get a solid hub clutch. When you get a flywheel there are 1 pin and 2 pin 210mm versions, get the clutch that matches.
Reply #2June 07, 2015, 11:36:06 pm
bryanb
  • 25
« Reply #2 on: June 07, 2015, 11:36:06 pm »
I thought the ff code trans was one of the phew a 210 flywheel would not clear the bell housing
Reply #3June 08, 2015, 10:11:52 am
  • 7837
« Reply #3 on: June 08, 2015, 10:11:52 am »
The OD of all the 020 flywheels are the same IIRC. The inside clutch surface is the only difference. I have seen 4 speed trans with 210 in them no issues.
Reply #4June 08, 2015, 10:23:42 am
bryanb
  • 25
« Reply #4 on: June 08, 2015, 10:23:42 am »
Ok thanks
