Author Topic: Can a tdi turbo/manifold unit be bolted onto a 1.6?  (Read 4997 times)
June 05, 2015, 04:00:29 pm
Sansocal
  • 34
« on: June 05, 2015, 04:00:29 pm »
A pretty simple question, as the title states. Can one of these, or something like this, be bolted onto a 1.6?  www.buyautoparts.com/plabuynow.asp?year=2010&make=Volkswagen&model=Jetta&partname=Turbocharger&partno=40-30660_R&gclid=CJDdxv3T-cUCFYdbfgodPa0APQ
Reply #1June 05, 2015, 07:25:00 pm
rabbid79
  • 684
Re: Can a tdi turbo/manifold unit be bolted onto a 1.6?
« Reply #1 on: June 05, 2015, 07:25:00 pm »
Yes, it can, but not that particular turbo.  That one is for a newer 16 valve engine.  You need one from an older 8V 1.9 TDI engine.
'15 WRX
Reply #2June 05, 2015, 08:55:42 pm
Sansocal
  • 34
« Reply #2 on: June 05, 2015, 08:55:42 pm »
Ok, so I'm assuming alh and ahu will work? Are all 1.9 tdi's 8 valve? I wouldn't ask that question if I knew of a database that had engine info.
Also, is there any particular reason people don't do it very often (besides it being a relatively small turbo)?
thanks for the reply!
Reply #3June 05, 2015, 10:11:38 pm
« Reply #3 on: June 05, 2015, 10:11:38 pm »
The AHU/1Z turbo will bolt up and is a wastegated turbo.  I think probably the ALH turbo is not used on the 1.6 very often because it is a VNT turbo and controlling the vanes adequately is a lot more of a challenge than just running a wastegated turbo.  I have an ALH VNT15 on a 1.6 rabbit.
Reply #4June 06, 2015, 06:37:01 am
Sansocal
  • 34
« Reply #4 on: June 06, 2015, 06:37:01 am »
Awesome, I didn't even know they made a tdi without a vnt turbo. How is the gt15 on your 1.6? I'd imagine it's about the same level of performance as a k14...
Reply #5June 06, 2015, 08:30:30 am
« Reply #5 on: June 06, 2015, 08:30:30 am »
The K14 is not even close.  I have run a couple VNT 1.6TD setups with properly functioning mechanical controls and the VNT15 with properly functioning vanes spools way faster than the K14 and flows better at high rpms/high boost.  The boost threshold is considerably lower than even a K03 and yet flows better at high rpm/high boost than a T3 or K24.  None of the stock VW wastegated turbos come anywhere close to the performance of a properly controlled VNT15 or 17 on a 1.6.
« Last Edit: June 06, 2015, 08:33:35 am by libbydiesel »
Reply #6June 06, 2015, 12:49:07 pm
Sansocal
  • 34
« Reply #6 on: June 06, 2015, 12:49:07 pm »
I was actually talking about the gt15 turbo, the non-vnt that came on the 1z engine.. that's right, Right?
I would love to have a vnt, but I do not have the time to mess around with a mechanical vane position controller. Maybe some day when im not so busy with school.
Reply #7June 06, 2015, 12:55:40 pm
Sansocal
  • 34
« Reply #7 on: June 06, 2015, 12:55:40 pm »
To be honest I'm actually not that interested in making this engine hi tech or anything.. I would actually prefer a normal waste gate turbo like an older idi diesel would have. I want it to be an example of a simple, efficient, and reliable old school diesel :) its not gonna be fast, just not slow as $%&#
Reply #8June 06, 2015, 01:52:02 pm
« Reply #8 on: June 06, 2015, 01:52:02 pm »
Ah, sorry.  I wasn't paying attention.  The GT15/K03 spool very quickly, quicker than the k14, but are also quite restrictive so even at stock boost pressure you can feel the lack at higher rpms.  With higher than stock boost the high rpm loss over a less restrictive/more efficient turbo at the same boost pressure is very noticeable.
Reply #9June 06, 2015, 09:02:11 pm
Sansocal
  • 34
« Reply #9 on: June 06, 2015, 09:02:11 pm »
Ok, Good to know.. thanks libby diesel!
Reply #10June 08, 2015, 10:16:42 am
Blue-Civic-Hybrid
  • 4
« Reply #10 on: June 08, 2015, 10:16:42 am »
Thanks for all that Info Libby, it was great reading about the VNT turbo system on an IDI 1.6
82 VW Caddy diesel- stockish...
