Author Topic: 1.6 na injectors  (Read 2196 times)
May 30, 2015, 05:59:26 am
nissannx
  • 75
1.6 na injectors
« on: May 30, 2015, 05:59:26 am »
I have a 92 1.6 na installed with leaky injectors and was wondering if injectors from a mk1 1.6 na mechanical head would work with my mk2 motor?
Reply #1May 30, 2015, 09:32:38 am
Re: 1.6 na injectors
« Reply #1 on: May 30, 2015, 09:32:38 am »
Yep, they'd be fine. Though just getting the injectors you have serviced would probably yield the best results... Or order a set from Performance Diesel and then send back your cores. Injectors most definitely do wear.
Reply #2May 30, 2015, 09:54:24 am
air-cooled or diesel
« Reply #2 on: May 30, 2015, 09:54:24 am »
prob time for a new set of injectors; a good place can be a little pricey, or shop around and sometimes you have to bite it; ive got more than one empty injector body from rockauto and like, then again i have 3 sets or so of injectors, most have to be tested by now, some i got incomplete. the extra price for like vanbc suggestion is well worth it.
