Author Topic: FS: 1.6TD parts & other misc MK1/MK2 parts, worth a look  (Read 8650 times)
May 22, 2015, 04:44:19 pm
EcoTX
  • 113
« on: May 22, 2015, 04:44:19 pm »
*UPDATED WITH PARTS STILL AVAILABLE*
Here's about 2/3 of my diesel parts hoard for sale and some other misc thrown in.
Let me know what all you want and I'll give you a price shipped.
1. MK2 NA diesel CCV breather rubber (valve cover to intake) - $5
2. MK1 NA diesel CCV breather rubber (valve cover to intake) - $5
4. TD oil filter flange - $20
6. TD intake manifold w/ BOV & rubber hose - $40
10. TD intake back heat shield - $5
11. Water pump housing/metal thermostat cover - $10
12. Front MK2 motor mount bracket - $5
13. Rear MK2 motor mount - $5
14. Diesel injection pump bracket - $5
17. Oil cooler, doesn't leak - $15
19. TD valve cover w/ CCV puck - $20
20. Water pump housing/metal thermostat cover - $10
21. Metal thermostat cover - $10
22. Rear MK2 motor mount - $5
23. Diesel injection pump bracket - $5
24. Diesel injection pump bracket - $5
25. TD intake hose from airbox (round MK2) - $40
27. TD valve cover w/ CCV puck and rubber hose to intake - $25
29. 1.6 Diesel intermediate shaft, fresh oil on bearing surfaces, no rust except surface in the middle part - $20
30. Dual exhaust manifold, not exactly sure what from - $30
31. MK1 diesel timing belt cover, great shape all rubber grommets in tact, not rotted, no rust - $25
32. MK1 5 speed transmission mount - $30
33. Cool lug wrench I've never seen before, it folds up on the end - $20
39. Engine hoist bracket - $10
41. Engine hoist bracket - $10
42. Injection lines, a bit rusty but still have life, use as spare set to make it home - $10
43. Injection lines, great shape will fit TD if needed - $25
44. MK1 diesel motor mount - $40
45. MK1 diesel motor mount - $40
46. OE 26mm oil pump with baffle, pulled recently from running engine, 100+psi cold - $40
47. OE 30mm oil pump with baffle, pulled recently from running engine, 100+psi cold - $50
48. Aftermarket 36mm oil pump, unknown condition, lash checks out though - $30
49. Vane vacuum pump - $40
50. TD oil pan bung cut-out - $10
51. Vane vacuum pump - $40
52. Vane vacuum pump - $40
53. Weighted shift rod - $10
54. TD ECO injection lines, for long delivery valves only - $60
55. Injection lines, great shape - $25
56. Dual downpipe with O2 bung, not sure what from some gasser, good shape - $30
57. Injection lines loose, spares - $Free
58. Injection lines loose, surface rusty but in great shape, ends haven't been over-torqued down great set of spares - $10
59. Vacuum hose from pump to booster - $5
60. Vacuum hose from pump to booster - $15
Not pictured (yet) but also for sale:
OE MK2 Jetta rear springs - $20
Box full of MK1 and MK2 alternators AC and Non-AC, all confirmed working - $40/piece
1.6 intermediate shaft, will need turned - $10
TD pump - $250
ECO pump, leaks from throttle shaft - $100
Injection pump - $60
OE jacks for spare, great shape - $25
Thanks for looking, PM with inquiries. :)
« Last Edit: June 04, 2015, 05:31:24 pm by EcoTX »
Reply #1May 22, 2015, 07:07:47 pm
Delete!
  • 6
Re: FS: 1.6TD parts & other misc MK1/MK2 parts, worth a look
« Reply #1 on: May 22, 2015, 07:07:47 pm »
PM sent
Reply #2May 23, 2015, 05:39:10 pm
Ra16it
  • 7
« Reply #2 on: May 23, 2015, 05:39:10 pm »
PM'd!
1984 Rabbit
Reply #3May 25, 2015, 07:20:15 pm
assforkr
« Reply #3 on: May 25, 2015, 07:20:15 pm »
Pm sent
Reply #4May 25, 2015, 07:30:41 pm
EcoTX
  • 113
« Reply #4 on: May 25, 2015, 07:30:41 pm »
Hey guys, I responded to most of your PM's.
It has been flooding here (Central TX) bad this weekend and my internet has been out since Saturday and still isn't back on.
Power went out today for about 6 hours as well...
Things are going slow on my end, but I am working on it, will have all PM's returned by middle of the week.
Thanks for the patience!
Reply #5May 28, 2015, 07:20:05 am
assforkr
« Reply #5 on: May 28, 2015, 07:20:05 am »
How are you faring with the flooding? Wish you luck man... and not just because I'm looking for parts. Ok Partly because of the parts. Good luck!
Reply #6May 28, 2015, 11:24:16 am
felipe1f
  • 31
« Reply #6 on: May 28, 2015, 11:24:16 am »
Hi,
Interested  in the vacuum line from booster to pump, if one way valve works ok. I'll check other parts  later to save on shipping, my zip code is 90262.
good look with the storms, stay safe.
Reply #7May 29, 2015, 04:05:17 pm
felipe1f
  • 31
« Reply #7 on: May 29, 2015, 04:05:17 pm »
I'm also interested in the turbo and the td oil pan, the one in good condition. let me know about the shipping cost.
Thanks
Reply #8June 03, 2015, 11:47:19 am
  • 2926
« Reply #8 on: June 03, 2015, 11:47:19 am »
I have a friend looking for a vaned vacuum pump.
 Let me know when things dry out and get back to somewhat normal down there.
Reply #9June 04, 2015, 05:51:16 pm
EcoTX
  • 113
« Reply #9 on: June 04, 2015, 05:51:16 pm »
Bumping this, got all the stuff that was pending the first few days shipped out.
Sorry to those that have been inquiring the past week or so and haven't heard back, all the "good stuff" was claimed within the first 48 hours of listing.
Shoot me a PM, I will get him one, same guy with the TD Rabbit?
I am actually moving to Iowa early next year, would love to meet up with yall, I'll have my 84 Rabbit 1.6NA up there.
Thanks
Hi,
Only have the vacuum line left...
Everything you were inquiring about was pending and got sold.
Reply #10June 06, 2015, 05:42:18 pm
juan.cobar
  • 8
« Reply #10 on: June 06, 2015, 05:42:18 pm »
Interested in Td intake, valve cover w puck and hose to intake and intake hose from airbox.
Reply #11June 07, 2015, 08:02:05 pm
  • 2926
« Reply #11 on: June 07, 2015, 08:02:05 pm »
Moving to Iowa soon eh? What part?
  Bring us up a rust free body to work on, ha.
 Bill is real happy with his TD fuel filter setup. We should have the factory TD running by the end of the year.
This vane pump is for a vanagon I'm working on in Ames.
 I'll send a PM.
Reply #12June 11, 2015, 12:37:45 pm
Ra16it
  • 7
« Reply #12 on: June 11, 2015, 12:37:45 pm »
Still interested in the intake boot (#8 ) if you have it!
1984 Rabbit
Reply #13November 26, 2015, 12:43:04 pm
deepgrooves74
  • 68
    • This is my build thread... Bucket.
« Reply #13 on: November 26, 2015, 12:43:04 pm »
I was wondering if you had number 31 the diesel timing belt cover still?
