Author Topic: left hand drill bits and brake rotor screw size  (Read 10124 times)
Reply #15May 24, 2015, 06:56:07 am
92EcoDiesel Jetta
Re: left hand drill bits and brake rotor screw size
« Reply #15 on: May 24, 2015, 06:56:07 am »
Impact screwdriver rarely fails me.  Anytime that screw goes back in its treated with anti seize.
In the auto parts store, go to the "help" section.  They have a pack of rotor screws for a Honda that's a perfect fit.
-Todd
Good to know. Are the autoparts store ones for Honda Phillips head? Are they stainless.
Reply #16May 24, 2015, 11:01:16 am
« Reply #16 on: May 24, 2015, 11:01:16 am »
Didn't catch the Torx versus Hex in your picture post.  I would go for Torx over hex as well.  They are better.  Philips not even on the list for consideration.  Thanks for the clarification.
With all the other hex head bolts on the VW you have to wonder how did they sneak those on their rotors in the first place?
Reply #17May 25, 2015, 06:19:47 am
« Reply #17 on: May 25, 2015, 06:19:47 am »
I think they developed torx to be less tampered with. FWIW I have stripped many more torx fasteners to a tune of at least 10 to 1 over a socket head. I have stripped more hex keys than socket heads and stripped more torx bits than hex keys. Even a button head socket has more to hold than a torx. YRMV...
Reply #18May 25, 2015, 08:02:39 am
92EcoDiesel Jetta
« Reply #18 on: May 25, 2015, 08:02:39 am »
I'd have to disagree with the tampering part. Very odd you stripped more torx than allen and socket head.
Reply #19May 25, 2015, 08:21:15 am
92EcoDiesel Jetta
« Reply #19 on: May 25, 2015, 08:21:15 am »
I was about to take the calipers and rotors off when I discovered a crack on one of the rotors. This crack is between 2 lug bolt. Is this common and what's the cause? I think it is due to a combination of rust between the rotor and hub (uneven surfaces) and me over torque-ing the lug bolts. I am now waiting for 2 new rotors before starting this job. I'll make sure to clean, sand and paint the hub before putting the new rotors on.
Reply #20May 25, 2015, 07:48:30 pm
« Reply #20 on: May 25, 2015, 07:48:30 pm »
Scary. Over torquing usually just warps rotors from my understanding, although if it's not against a flat surface than anything is game.
Reply #21May 25, 2015, 08:55:56 pm
92EcoDiesel Jetta
« Reply #21 on: May 25, 2015, 08:55:56 pm »
it is very possible the uneven surface is presented by the slightly protruding broken screw stud if the rotor screw hole is not lined up during wheel install. I'll take a closer look at the rotor for marks left by the broken screw.
Reply #22May 25, 2015, 10:48:12 pm
« Reply #22 on: May 25, 2015, 10:48:12 pm »
theman53,  IF you are stripping out a torx head more than a hex you are doing something out of the ordinary.  Perhaps your bits are worn?  They are designed to bite better than a hex so you shouldn't be stripping them out at all.  I would be looking at your technique and your tools.
Reply #23May 26, 2015, 05:08:23 am
« Reply #23 on: May 26, 2015, 05:08:23 am »
Nope.
Try to find *yes there are some* but seriously try to find a torx drive fastener over 10mm-1.5 thread in a 12.9 grade. They almost don't exist. Why wouldn't they want the best engagement in the bigger sizes? Maybe they are using the best engagement. I sell bolts to OEM mfg and pretty much the only reason they will use torx is in a spot where they don't want someone to take it apart with tools found under the kitchen sink. They don't have as much meat by design as they are not supposed to need it, but in the real world the design seems to disagree...again YRMV
Reply #24May 26, 2015, 08:35:32 am
92EcoDiesel Jetta
« Reply #24 on: May 26, 2015, 08:35:32 am »
Critical fasteners such as CV axles, cyl head bolts etc are all Torx. Tamper proof fasteners are usually found in public rest rooms, not on cars.
Reply #25May 26, 2015, 08:48:33 am
« Reply #25 on: May 26, 2015, 08:48:33 am »
None of the VW CV bolts are Torx.  They are all either allen or triple-square.
Reply #26May 26, 2015, 08:15:55 pm
« Reply #26 on: May 26, 2015, 08:15:55 pm »
92EcoDiesel, I had to laugh as I thought Hmmm, lets try those counterclockwise regular screwdriver type security nuts on that rotor.  Bet theman would be sooooo pissed about that.
Reply #27May 29, 2015, 07:04:55 am
air-cooled or diesel
« Reply #27 on: May 29, 2015, 07:04:55 am »
i like those screws, and shinny too; that pic of your rotor looks like sh*t, ive never had a rotor look that bad, its been sitting around for a while or something else is wrong for it to look like that, brake area should be bare metal, some rust will get wiped away when you brake, too much and you will ,i guess, get bad wear patterns, or chew up pads.
phillips screws are about 25 ft lbs break, max, that is if screw head doesnt strip before, which it usually does, or gets rusted in, an allen head is a big step up, torx is another step up and should hold up to mid torque. you shouldnt have many striping problems with torx, unless you have another problem, rust, overtightening, cross-thread when you put it in, ?possibly a chewed up tool?. my cv bolts are like 8-point, maybe more point, have a snap-on tool for that. i do believe cv bolts are hardened too.
Reply #28May 29, 2015, 12:28:46 pm
  • 2931
« Reply #28 on: May 29, 2015, 12:28:46 pm »
I use an impact screwdriver (I impact a screwdriver with a hammer) to remove them.
 Put the screwdriver in the screw and hit it with a hammer,.. to loosen it up.
Works great.
« Last Edit: June 03, 2015, 11:29:20 am by fatmobile »
Reply #29May 29, 2015, 12:57:55 pm
ToddA1
  • 434
« Reply #29 on: May 29, 2015, 12:57:55 pm »
Philips head and not stainless. If you anti seize them, they should never be an issue.
The only time I use the impact screwdriver is to break them free if I pick up another car. These screws don't need to be super tight.... hand tight is fine. The screws are only there to hold the rotor.
-Todd
