Author Topic: T 25 1.6 td slow hill climb  (Read 28360 times)
May 20, 2015, 10:19:53 am
ChrisD
  • 1
« on: May 20, 2015, 10:19:53 am »
Hi this is my first pos so probably in the wrong place but here is the problem.
I have changed the fuel lines as there were bubbles in the deisel and the fuel and oil filter which improved the situation, but its still strugling on hills and send out black smoke not too much but its there. I think it's a Turbo problem. Any ideas as to how I can sort this out? ???
Reply #1May 20, 2015, 12:54:58 pm
  • 7834
Re: T 25 1.6 td slow hill climb
« Reply #1 on: May 20, 2015, 12:54:58 pm »
Black smoke usually means you have fuel.
It is a diesel, black smoke is somewhat normal, you can adjust the fuel if that is all it is. Also, if this is the first one you have owned, it is not a gas car and if you are taking a hill in top gear at 35 you just need to downshift and it will go away.
If you suspect turbo take the intake boot off and try to see if you get wiggle in the shaft. If you do have in and out play then I would take a really good look at the turbo or send it out for inpection/rebuild.
Reply #2May 21, 2015, 07:41:30 am
« Reply #2 on: May 21, 2015, 07:41:30 am »
I'd tee into the boost line to the injection pump with a long line to a boost gauge in the cabin. See if the turbo makes boost on a steep hill.
Low boost will likely result in sooty smoke. ~10psig is normal.
And as noted above, heavy loading or lugging the engine can result in some sooty smoke.
Reply #3May 23, 2015, 11:24:31 am
  • 1739
« Reply #3 on: May 23, 2015, 11:24:31 am »
try to go downhill more ? ( sorry)
Reply #4May 25, 2015, 10:43:03 am
deepgrooves74
  • 68
    • This is my build thread... Bucket.
« Reply #4 on: May 25, 2015, 10:43:03 am »
Really...
I unfortunately thought that this was quite funny
« Last Edit: May 27, 2015, 05:51:47 pm by deepgrooves74 »
Reply #5September 06, 2015, 09:42:52 pm
Sansu
  • 5
« Reply #5 on: September 06, 2015, 09:42:52 pm »
right and possible
Wenn das Leben dir 100 Gründe zum Weinen gibt, zeig, dass du 1000 Gründe zum Lachen hast. iphone 6s plus tasche
Reply #6January 05, 2019, 12:17:03 pm
JameBUYv
T 25 1 6 td slow hill climb
« Reply #6 on: January 05, 2019, 12:17:03 pm »
I have seen that crazy looking purple/yellow car at the Rob Roy Hill climb a couple of times.
Reply #7August 13, 2019, 06:00:12 am
seamaster301
  • 6
« Reply #7 on: August 13, 2019, 06:00:12 am »
Did you ever find out what was causing the power issue?
Reply #8November 10, 2021, 01:25:07 pm
ernst60
« Reply #8 on: November 10, 2021, 01:25:07 pm »
Hello, it is probably fuel because the black smoke means that the fuel needs to be adjusted and it should be good to set the pressure right, I had the same problem, I set the injectors to the same pressure and now it is good, but in another car
