Author Topic: problems with start after rebuild pump - AAZ  (Read 6949 times)
May 18, 2015, 11:41:59 pm
berton7
  • 2
« on: May 18, 2015, 11:41:59 pm »
Hello
I need some help from you diesel experts.
My pump was leaking on LDA. I open it and changed main seals.
But I mess up something when putting back together.
Only thing that has 2 options was cam plate(number 3 on picture)
When I start the engine went directly to max RPM!?!?!
Any suggestions what I did wrong?
I put pump back down and and turn the cam plate (number 3 on picture). Now I don't have enough pressure to let the air from pipes. Fuel don't came out from the pipes.
SORRY, cant load picture - try google ''Distributor head'' you will see Distributor head apart with numbers...
SO I must give it one more shot.
Last one with your help I hope ;)
Thanks! Berton
« Last Edit: May 18, 2015, 11:55:03 pm by berton7 »
Reply #1May 19, 2015, 06:36:13 am
Re: problems with start after rebuild pump - AAZ
« Reply #1 on: May 19, 2015, 06:36:13 am »
Sounds like you need to adjust the max fuel screw a bit. Turn it in some until you are getting fuel.
Reply #2May 19, 2015, 04:04:47 pm
berton7
  • 2
« Reply #2 on: May 19, 2015, 04:04:47 pm »
after lot of rebuilding post and pictures I rebuild it one more time today and tomorrow we'll see a progress ;)
Reply #3February 07, 2017, 12:36:24 pm
retroloose
  • 8
« Reply #3 on: February 07, 2017, 12:36:24 pm »
Hi Berton did you ever find the problem with your pump after trying to replace Lda seal .
The exact same thing has happend me i thought i put it back together right but it just goes to max revs the minute i start engine.
Jordan
