Author Topic: Turbo setup: am I missing anything?  (Read 5695 times)
May 11, 2015, 09:19:30 am
Smoker
  • 255
« on: May 11, 2015, 09:19:30 am »
Getting ready to turbo my n/a 1.6.
I have
-vnt15 and downpipe
-alh and ahu intake manifolds to pick from... I also have a g60 mani that I want to use later, when I add an intercooler.
-oil return line
-oil supply line... For this, I have a hard line from an alh car that I reshaped to line up with the top of the oil filter housing. I'm assuming/hoping I can just drill and tap the top of it for the banjo bolt?
For now, I'm planning on using my original n/a pump, but I have a late mk2 pump with the anti-soot dealie or whatever that I'm eventually planning on resealing and swapping the ports.
I know I still need:
-boost piping kit
-boost and egt gauges
Any specific recommendations on this stuff? Where to buy? And am I missing anything? I'm hoping to do this with as little down time as possible.
Reply #1May 11, 2015, 09:53:37 am
Re: Turbo setup: am I missing anything?
« Reply #1 on: May 11, 2015, 09:53:37 am »
What are you going to use to control the vanes?
Reply #2May 11, 2015, 10:56:34 am
Smoker
  • 255
« Reply #2 on: May 11, 2015, 10:56:34 am »
Fixed position, although I need to do some more research on that.
Reply #3May 11, 2015, 02:56:25 pm
« Reply #3 on: May 11, 2015, 02:56:25 pm »
Air filter/housing/piping?
Oil pan provisions for return line?
Reply #4May 11, 2015, 03:00:58 pm
Smoker
  • 255
« Reply #4 on: May 11, 2015, 03:00:58 pm »
I'm on the oil pan provisions. Got a fitting that I'm having a tig guru buddy of mine graft in. As far as air filter, I have a generic "cold air" filter from an alh car I parted out, as well as a box full of random pipe/hose/clamps from parted out cars...
Reply #5May 12, 2015, 08:30:02 am
Smoker
  • 255
« Reply #5 on: May 12, 2015, 08:30:02 am »
Ordered my gauges today. I think the only thing I'm missing is boost piping... Anyone have suggestions on that? Gotta be cheap!
Reply #6May 12, 2015, 08:48:58 am
« Reply #6 on: May 12, 2015, 08:48:58 am »
You might want to upgrade the oil pump to 36mm gears as the turbo bearings consume a fair amount of oil.  You're probably fine with 30mm gears, though, if you don't have the piston cooling oil jets.
Reply #7May 12, 2015, 03:49:56 pm
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« Reply #7 on: May 12, 2015, 03:49:56 pm »
If you have a stock 1.6 cylinder head, the intake ports are oval and the AHU/ALH manifolds you have "D" shaped ports and can leak at the head interface due to the profile mismatch no matter which gasket(s) you use.      You might want to use the G60 manifold now, and I'd recommend at least a 2.25" exhaust system  from the turbo back.
Reply #8May 12, 2015, 04:33:58 pm
« Reply #8 on: May 12, 2015, 04:33:58 pm »
You need to come up with a plan for the CCV as well since it can no longer go into the manifold, it needs to be preturbo.
Reply #9May 12, 2015, 05:54:36 pm
Smoker
  • 255
« Reply #9 on: May 12, 2015, 05:54:36 pm »
Good call, I hadn't thought of that... Suggestions?? Just plumb it into the intake tube between the air filter and turbo?
Reply #10May 13, 2015, 10:37:56 am
« Reply #10 on: May 13, 2015, 10:37:56 am »
That's what I did on mine...
Reply #11May 14, 2015, 04:26:17 am
Rock3tman
  • 113
« Reply #11 on: May 14, 2015, 04:26:17 am »
If you're going to use an intercooler, you may want to consider some sort of catch can system to minimize oiling of stuff upstream of combustion chamber.
Reply #12May 14, 2015, 10:04:11 am
« Reply #12 on: May 14, 2015, 10:04:11 am »
I'm of the opinion that oil in the intake tract is a good thing. It helps to catch any dust/dirt that makes it past the filter.
Reply #13May 14, 2015, 10:26:51 am
« Reply #13 on: May 14, 2015, 10:26:51 am »
The oil counts as fuel too. It doesn't harm anything but people often seem to have a problem with it. VW and virtually all car makers seem to think it's fine.
Reply #14May 14, 2015, 06:25:31 pm
Smoker
  • 255
« Reply #14 on: May 14, 2015, 06:25:31 pm »
Anyone have advice on this?  I know plenty of people have done it, but for some reason my googling hasn't found me any real specifics on it.
