Author Topic: AAZ power steering pump bracket  (Read 4128 times)
April 30, 2015, 07:10:37 pm
RunninWild
  • 609
« on: April 30, 2015, 07:10:37 pm »
Having trouble tracking one down for my build. Anyone know if this is the correct one or would fit my aaz block?
Or better yet anyone have one they want to let go for cheap?
Reply #1May 01, 2015, 09:53:37 am
Re: AAZ power steering pump bracket
« Reply #1 on: May 01, 2015, 09:53:37 am »
The bolt spacing where it bolts to the side of the block looks right, but it could still be from an ABA.
Reply #2May 01, 2015, 04:11:02 pm
RunninWild
  • 609
« Reply #2 on: May 01, 2015, 04:11:02 pm »
028 145 544 C  is the part number he's listing but nothing comes up on Google other then Russian sites... does that number look right to anyone or should I request him to double check it for a 2nd time?
Reply #3May 02, 2015, 11:01:37 am
Reply #4May 02, 2015, 05:51:58 pm
boukrev
  • 3
« Reply #4 on: May 02, 2015, 05:51:58 pm »
Just took mine off an AAZ and the part no is ok except mine ends in an E. so should be correct
Reply #5May 02, 2015, 06:10:30 pm
« Reply #5 on: May 02, 2015, 06:10:30 pm »
http://www.jimellisvwparts.com/products/Support----------------------also-use/5131883/028145544E.html
Looks right
I think I'm changing my mind. The Jim Ellis site looks a lot different when I look at it on the computer instead of the phone
Reply #6May 02, 2015, 07:19:33 pm
RunninWild
  • 609
« Reply #6 on: May 02, 2015, 07:19:33 pm »
Reply #7May 02, 2015, 08:51:05 pm
« Reply #7 on: May 02, 2015, 08:51:05 pm »
Ahhhh this is so confusing! How about this guy? http://www.ebay.com/itm/161692680211?item=161692680211&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr
Won't fit unless you have a welder.
I can probably get you one in a few weeks when I head back to Canada...
Reply #8May 02, 2015, 09:06:04 pm
RunninWild
  • 609
« Reply #8 on: May 02, 2015, 09:06:04 pm »
thatd be excellent! I'm not in a rush just trying to track everything down. Let me know when your home and we can figure out the details
Reply #9June 02, 2015, 09:14:23 pm
RunninWild
  • 609
« Reply #9 on: June 02, 2015, 09:14:23 pm »
I went ahead and bought the bracket and it looks like its going to fit on my block. Does anyone know if the cage/mounting bracket for the pump is the same as the ABA? I saw it mentioned in a forum post but wanted to confirm.
are the 2 different style aba brackets I've found...
