Author Topic: AAZ crank Wobble. Opinions please!  (Read 6514 times)
April 27, 2015, 08:58:40 am
boomenstein
  • 35
« on: April 27, 2015, 08:58:40 am »
https://youtu.be/dt0oc9IA87M
Above is a link to a video of my wobbling crank. It doesn't look so bad with the Pulley off so just looking for opinions from anyone who has experience with this issue.
I just want to drive my car .
Should I be worried?
Reply #1April 27, 2015, 11:09:53 am
Re: AAZ crank Wobble. Opinions please!
« Reply #1 on: April 27, 2015, 11:09:53 am »
That is BAD... You are not far away from having your engine ruined.  Yes, you should be very very worried.
Reply #2April 29, 2015, 11:30:40 am
boomenstein
  • 35
« Reply #2 on: April 29, 2015, 11:30:40 am »
Anyone know where to get this done in Ontario?
I talked to Giles but he is not sure when the guy will be in to do it.
Would like to make it to spring Fling!
Reply #3April 30, 2015, 05:00:37 pm
RunninWild
  • 609
« Reply #3 on: April 30, 2015, 05:00:37 pm »
pretty standard fix is to have it machined to a TDI sprocket.
I'm about to get my block sent off for machining. Does anyone know what TDI sprocket should be used or do any of them fit?
Reply #4May 01, 2015, 09:55:32 am
« Reply #4 on: May 01, 2015, 09:55:32 am »
AHU or 1Z. You need a clutched alternator pulley too though. There are quite a few reports of stock TDIs failing and the clutched alternator pulley is suppose to help.
Reply #5May 01, 2015, 04:16:09 pm
RunninWild
  • 609
« Reply #5 on: May 01, 2015, 04:16:09 pm »
. Would pinning the stock crank and sprocket be a better solution assuming the stock sprocket is still in good shape?
Reply #6May 01, 2015, 04:47:33 pm
« Reply #6 on: May 01, 2015, 04:47:33 pm »
I don't think so but not sure. My reasoning is you have a forged crank that is probably stronger than whatever pin you put in to it. 4 pins and the D sprocket would be best but if it is one or the other I would go with the D sprocket.
Reply #7May 01, 2015, 06:03:13 pm
« Reply #7 on: May 01, 2015, 06:03:13 pm »
Personally I think the pins are kind of silly. Unless they're made out of something REALLY strong they can't even come close to the strength of the original keyway. D-sprocket plus a properly torqued NEW bolt and the alternator pulley is a pretty reliable solution.
Reply #8May 01, 2015, 06:20:48 pm
RunninWild
  • 609
« Reply #8 on: May 01, 2015, 06:20:48 pm »
I'll try and track down a new sprocket then.
Are alternator pullies usually interchangeable?  Reason being I'll be using a suzuki samurai alternator on my AAZ. ..
Reply #9May 03, 2015, 03:01:51 pm
vwzzuk
  • 88
    • http://www.acmeadapters.com
« Reply #9 on: May 03, 2015, 03:01:51 pm »
This is the TDI sprocket I use for the crank mod: 028 105 263 D
81 Rabbit Pickup, 1.9NA
85 Suburu Brat, 1.9TD AAZ
87 Suzuki Samurai, 1.6TD
92 Sidekick 4dr, 1.9TDI
Reply #10May 04, 2015, 11:43:04 am
« Reply #10 on: May 04, 2015, 11:43:04 am »
Any particular reason for using the Suzuki alternator instead of a VW one?  Sounds like a pain...
Reply #11May 04, 2015, 12:03:16 pm
RunninWild
  • 609
« Reply #11 on: May 04, 2015, 12:03:16 pm »
the vw alternator sits in a location that would interfere with the steering box. The mounting kit to use the engine comes with a bracket that relocates the alternator to the the exhaust side of the engine. I imagine they went this way over the vw alternator to save any rewiring or to make parts easier to find.
Reply #12May 04, 2015, 09:19:11 pm
« Reply #12 on: May 04, 2015, 09:19:11 pm »
Is the alternator a Bosch, or something else?
Reply #13May 05, 2015, 06:58:27 am
« Reply #13 on: May 05, 2015, 06:58:27 am »
If it's a v-belt you don't need to worry about the clutched alternator pulley. It slips enough to not cause crank issues (as the theory goes).
Reply #14May 05, 2015, 05:10:37 pm
RunninWild
  • 609
« Reply #14 on: May 05, 2015, 05:10:37 pm »
Well thats good to know. V belt saves the day! My machinist is going to inspect my crank and if its in good shape he said he would pin it. If it needs to be replaced were going to go with the tdi sprocket. He said hes done both repairs on AAZ's and hasnt had any problems with pins on any of his rebuilds.
