Author Topic: W terminal on alternator for tach signal  (Read 8821 times)
August 12, 2004, 07:56:15 pm
veritas137
  • 12
« on: August 12, 2004, 07:56:15 pm »
Was told that if my alternator has a W terminal on it, I can plug in a cluster with a tach and it will work.  Problem is I have no idea what this W terminal looks like.  Anyone have a pic or can tell me what I'm looking for?
Tim
2003 Saab 9³ - hers
1999 Ford F250 - his
1986 VW Golf Diesel - his
Reply #1August 13, 2004, 10:44:45 am
BlackTieTD
  • 1512
« Reply #1 on: August 13, 2004, 10:44:45 am »
needs to be a diesel tach... a gasser tach wont work. gasser tach is looking for a signal from the coil... sine wave vs. some whozamawhutzis and all that.
to be honest i havent looked for a W-terminal, dunno what it looks like to describe it... but i believe it should have either a W or a number stamped next to it. a "25" maybe?
if you have your alternator cracked open at a rebuild shop of some kind, they can usually tap into the signal you need and give you a terminal to hook up to... even if your alternator didn't originally come with one.
Reply #2October 28, 2004, 06:27:27 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #2 on: October 28, 2004, 06:27:27 pm »
There should be a feed to the clocks already other wise the oil pressure warning system wouldnt work, just a case of sawpping the clusters over.
se my reply to this post: Switching gauge clusters
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #3October 28, 2004, 07:03:13 pm
veritas137
  • 12
« Reply #3 on: October 28, 2004, 07:03:13 pm »
Thanks for the info guys, still need to find a tach and do this.
Tim
2003 Saab 9³ - hers
