Author Topic: Replacement turbo drain line for KKK14 turbo  (Read 3744 times)
April 18, 2015, 11:55:01 am
FrankenDiesel
  • 59
« on: April 18, 2015, 11:55:01 am »
Hey guys,
Im converting my na idi to kkk14 turbo setup. The drain line was tapped in a weird spot, and I was looking to replace/upgrade it. Does anyone know the specs for the fitting or where to get a replacement turbo drain?
Reply #1August 08, 2015, 06:56:37 pm
hanisbb21
  • 18
Re: Replacement turbo drain line for KKK14 turbo
« Reply #1 on: August 08, 2015, 06:56:37 pm »
I'm actually doing something very similar right now. I'm going to a shop in town where they specialize in AN fittings. You will need a turbo oil pan, injection pump (preffered over NA pump tuning), turbo with manifold, and the above said drain pipe. I'd also strongly recommend Boost / Oil temp/pressure gauges as well. EGT gauge is a MUST. I tried ordering the oil drain fitting for the turbo for a 82 Jetta TD but the fitting ended up being the wrong size from VW. Any idea of what year/model to order the fitting from (just in case I can't get a custom fitting, I'm using the KKK k14 as well). I'll post pictures and specs for the parts when I get them on Monday.
Reply #2August 16, 2015, 08:33:42 pm
hanisbb21
  • 18
« Reply #2 on: August 16, 2015, 08:33:42 pm »
700109 and 9919efk are the part numbers for the fittings @ ANplumbing.com on the oil drain for a kkk k14 Turbo. The thread size is 16.5 x 1.5. The common thread on the VW oil pans is 22mmx1.5mm. I'm having some trouble finding AN fittings for that so if  you come up with anything let me know.
Reply #3August 17, 2015, 06:45:45 am
« Reply #3 on: August 17, 2015, 06:45:45 am »
There are 2 K14 turbos. One from the 1.6 eco diesel and one from the AAZ engine. They have different style drain lines IIRC.
