Author Topic: Running an AAZ as a 1Y  (Read 2423 times)
April 18, 2015, 09:53:10 am
FatmanGolf
  • 14
« on: April 18, 2015, 09:53:10 am »
Hi guys... Have a few questions.
Basically I have an AAZ here with a blown turbo that I'm selling. I have a friend interested in it but they want to know if they could run it as a 1Y instead of an AAZ. They are putting it into a t25 camper and don't want the hassle of making up engine mount brackets, exhaust downpipes, etc for it. Just something with a bit more power to help pull the camper up hills that's more or less a direct bolt in replacement.
So my question... Could you run a standard AAZ as a 1Y? Would you need to swap the AAZ pump for a 1Y pump? Compression ratios be ok? And would it still make 1Y power?
Cheers
Stefan :)
Reply #1April 18, 2015, 11:30:42 pm
Re: Running an AAZ as a 1Y
« Reply #1 on: April 18, 2015, 11:30:42 pm »
Yup, it would be fine. Might need the fuel screw tweaked a bit but other than that it'll behave exactly like a 1Y.
Reply #2April 19, 2015, 09:02:17 am
  • 1739
« Reply #2 on: April 19, 2015, 09:02:17 am »
Sure. I ran my T3 as a 1Y, but had a big intake and exhaust with a Giles pump. I'm 99 sure I had more torque than a JX and would pull strong past 5000 rpm
Reply #3April 19, 2015, 03:15:33 pm
FatmanGolf
  • 14
« Reply #3 on: April 19, 2015, 03:15:33 pm »
Ah! Good to know guys. Thanks for the reply :).
The AAZ pump has a shimmed governor and a few tweaks to the fuel screw so should help it along a bit. :D.
